Thread: Are Kole Audio amps any good? |
New member Username: Fuzze
Post Number: 1 Registered: May-04
| Posted on Monday, May 10, 2004 - 12:43 pm: |
i was jw uf they are any good and if MA audio subs are any good thanx |
NorthWest,
Michigan
Post Number: 2803 Registered: Dec-03
| Posted on Monday, May 10, 2004 - 12:48 pm: |
"Kole" is another in a long line of knock-off "similar name" companies trying to confuse people. KOVE Audio is a high end company. Kole is shady, like "Rockwood" or "DHD" I'd save up and spend a bit more to get some reliable stuff, if it were me.
Post Number: 2 Registered: May-04
| Posted on Monday, May 10, 2004 - 01:01 pm: |
what about ma audio i was looking to buy the MA AUDIO KORE15 good or bad? |
NorthWest,
Michigan
Post Number: 2808 Registered: Dec-03
| Posted on Monday, May 10, 2004 - 01:08 pm: |
people seem to have mixed opinions about MA. some love em, some don't like em at all. I find MA to be on par with Audiobahn. flashy chrome, not huge on performance. My advice is listen to a set. If you like them, then buy them. In the end, it's your ears that should be happy.
