Home > Message Board > Car Audio > Amplifiers > Archive through May 14, 2004 > Rockford Fosgate Power 300 Amp Questions
Author Thread: Rockford Fosgate Power 300 Amp Questions
Username: Stugots
Just a some questions about this AMP, can anyone tell me where to find some info like the manuel or anything on the Web im not having much luck...And if anyone can tell me if its a good AMP and some specs,i can get one for about $200 Canadian
Username: Glasswolf
NorthWest, Michigan
Post Number: 2805
if that's the old two-channel model, it's a 300.2
that's rated for 75wRMS x 2 @ 4 ohms I believe
300w x 1 @ 4 ohms
email RF's website with the model and ask for a manual.
Username: Stugots
So how would that amp do with 2 Alpine Type R's 12"
Username: Glasswolf
NorthWest, Michigan
Post Number: 2810
underpowered.
each type R should get at least 300wRMS or so for good performance.
I've seen them given as much as 600 watts each, but 300 each works very well, so a 600 watt mono amp is good for two type R subs
Username: Stugots
Ok well ill tell this person i dont want that AMP, What would you suggest just remember im in Canada :P...perhaps something in a Rockford Fosgate model???
Username: Glasswolf
NorthWest, Michigan
Post Number: 2820
a JBL BP600.1 would do fine, and it's cheap.
Username: Stugots
Ok so how would you wire that from the + on Amp to the + on speaker 1 and - from amp to - on speaker 2...and then a wire from + to - speaker to speaker?
if you had 2 amps that were each rated for a 50 amp fuse, would you just get a 100 amp fuse? or is there an equation to use in order to find out how big of a fuse to get.
Username: Glasswolf
NorthWest, Michigan
Post Number: 2825
the JBL amp has two sets of speaker terminals.
connect one sub to each set.
done.
for the fuses, yes add the ratings.
two 50A fused amps would need a main line fuse of 100A.
Home > Message Board > Car Audio > Amplifiers > Archive through May 14, 2004 > Rockford Fosgate Power 300 Amp Questions [ « Previous ] [ Next » ]
