Thread: How exactly do you bridge an amp? |
New member Username: J_capone
Chicago,
IL
Post Number: 7 Registered: May-04
| Posted on Sunday, May 09, 2004 - 10:47 pm: |
ok.. i never done this before..and i found a little tutorial, but it seems like it was for hooking up one sub only.. question is..do you only bridge an amp if you have one sub? if not.. then how would that work? i have a boss ripper amp..2 channel thats bridgeable..with 2 audiobahn subs.. anybody? |
| Posted on Sunday, May 09, 2004 - 11:11 pm: |
you can not bridge 2 subs with a 2 channel amp you bridge 2 subs when using a 4 channel amp. you just wire them strait to the amp that is giving you a 2 ohm load that is all you can do with that unless you got the money to get a 4 channel but it will sound good hooking it up let i said. |
NorthWest,
Michigan
Post Number: 2801 Registered: Dec-03
| Posted on Sunday, May 09, 2004 - 11:53 pm: |
http://www.bcae1.com/bridging.htm
Chicago,
IL
Post Number: 8 Registered: May-04
| Posted on Monday, May 10, 2004 - 12:12 am: |
damn..nice link good stuff thanks |
