Home > Message Board > Car Audio > Multimedia Systems > Archive through November 18, 2006 > Jensen VM9411 TV problem
Author Thread: Jensen VM9411 TV problem
Username: Sabian_mx
Hi: I have a problem with my unit. I've already installed the switch for the DVDs, and works great. The problem is the TV. I can hear the audio, but only get a BLACK SCREEN. Please help.
Username: Kickdoor
so did you connected the pink wire to the emergency brake?
Username: Sabian_mx
Yes, I have no problem at all to watch DVDs, but the TV only give me a BLACK SCREEN and the ipod's video or photos only a BLUE SCREEN and the sound.
Username: Psychedelic_feta
Victor:
I had the same problem too and here's what I did. This is not written properly on the wiring diagram.
You Have to connect the MEDIA MODULE VIDEO INPUT cable (Yellow) into the CVBS (Yellow) cable. Essentially, you're getting hte sound but no video because the two signals are on different cables, one of which you likely didn't hook up.
As for the blue screen, I just posted a free factory unlock code in the "multimedia systems" forum...Don't get sucked in by those punks trying to sell it to you.
The code PERMANENTLY disables the blue screen.
Anything else I can help you with?
Username: Sabian_mx
THIS SOLVE THE PROBLEM, MANY THANKS!!!!
Username: Wellington
Wellington, Westerncape
South Africa
I have installed a VM9411. Every thing works and I sorted out the breaking - activation problem. My problem is the TV. The headunit does not read the TV. The SRC/P.Mode - shows - Tuner,DVD/CD,Aux and Camera but no TV.
No signal from the Media Module, the red light is on so the module is working.
Can someone help me. South Africa works on Pal
Username: Jaithecutie
Panhandle, FL
I dont have a problem with the TV or anything of such... but I would like to know how to utilize this "screen saver" feature.
Nothing changes whether it's on/off.
Home > Message Board > Car Audio > Multimedia Systems > Archive through November 18, 2006 > Jensen VM9411 TV problem [ « Previous ] [ Next » ]
