Thread: Jensen vm9411 blue screen problem |
New member Username: Vipermonza
Sartell,
Mn
Post Number: 1 Registered: Oct-06
| Posted on Tuesday, October 03, 2006 - 04:57 pm: |
I just installed the Jensen vm9411 in my car and everything works fine, I can watch DVD's, so I know the e-brake switch wire is connected correctly, but all I get for the t.v. function is a blue screen that says "no signal", I've tried everything to make it work but nothing happens, does anybody know what might be wrong? |
New member Username: Psychedelic_feta
Post Number: 6 Registered: Oct-06
| Posted on Sunday, October 15, 2006 - 08:46 pm: |
Dale: make sure the media module is hooked up properly, provided the vm9411 comes with a media module. If not, or if yes, make sure the antenna is properly attached. Could it also be you may be confusing the TV function with the AUX function? Because it wouldn't say "No signal" in the TV mode, but rather it would give you snow like when your home television is disconnected from the cable. I hope this helped, anythign else? |
