Home > Message Board > Car Audio > Head Units > Archive through October 22, 2006 > Pioneer DEH-P860MP RCA grounding problem
Author Thread: Pioneer DEH-P860MP RCA grounding problem
Username: Illuminator
Post Number: 4808
I recently purchased and installed a Pioneer DEH-P860MP and it was working great. I then shifted it around a bit, and now there is some major static coming through the RCA outputs, I hear this is common and is related to some type of grounding problem? What can be done to fix it? There is no noise from the head unit's internal amp...
Post Number: 4809
I burned the shield ground, had to jumper the RCA shields to the head unit casing. Good times.
Home > Message Board > Car Audio > Head Units > Archive through October 22, 2006 > Pioneer DEH-P860MP RCA grounding problem [ « Previous ] [ Next » ]
