Home > Message Board > Car Audio > Security Systems > Archive through November 24, 2006 > Ford e 150 van Wiring diagram for rem...
Author Thread: Ford e 150 van Wiring diagram for remote starter
Username: Romic00
Post Number: 45
HI i am looking for a ford e150 van wiring diagram for a remote starter. If anyone can help i would appreciate it. Thank you
Username: Romic00
Post Number: 47
the year is 2006
Username: Motomaze
Ont
Post Number: 30
is that an econoline van?
Username: Tjmutlow
Post Number: 2887
12volts
lt. green/pur (x3)(common 60A)
ignition harness
Starter white/pink + ignition harness
Second Starter N/A
Ignition pink/lt. green + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory gray/yellow (x2) + ignition harness
Second Accessory black/lt. green + ignition harness
Keysense black/pink - ignition harness
Power Lock red to orange/black 5wi either kick, door harness
Power Unlock brown to yellow/red 5wi either kick, door harness
Lock Motor pink/black 5wi VSM in passenger kick
Unlock Motor red/orange 5wi VSM in passenger kick
Parking Lights+ brown + headlight switch or VSM
Parking Lights- N/A
Hazards same as turn signal wires
Turn Signal(L) lt grn/wht (F), lt grn/org ® + turn signal switch
Turn Signal® wht/lt blu (F), org/lt blu ® + turn signal switch
Reverse Light black/pink + driver kick, harness to rear
Door Trigger see notes - each pin switch or VSM
Dome Supervision black/lt. blue + relay to right of steering column
Trunk/Hatch Pin common with pass. door trigger
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Tachometer white/pink ac PCM, top plug, pin 25
Wait to start see DirectFax document 1091
Brake Wire dk. green + brake pedal switch
Parking Brake lt. green/red - parking brake switch
Horn Trigger dk. blue - horn switch or VSM
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Modules
Smart Starter Kill Relays
MAKE : FORD | MODEL : ECONOLINE | YEAR : 2006
* The logo is registered trade mark of Ford Corporate.
Username: Euroscort
would this wire diagram work for my ford escort 16v 1.6 1997? i have a clifford 950 with remote start got the rest working fine just need some advice cheers
Username: Euroscort
Home > Message Board > Car Audio > Security Systems > Archive through November 24, 2006 > Ford e 150 van Wiring diagram for rem... [ « Previous ] [ Next » ]
