Home > Message Board > Car Audio > Multimedia Systems > Archive through November 18, 2006 > Sd CARD SIZE FOR jENSEN 9511ts
Author Thread: Sd CARD SIZE FOR jENSEN 9511ts
Username: Dchap
Pittsford, New York
Player is working perfect, although TV reception could be better.
My question is this, has anyone tried an SD card larger than 1Gig? The 1G card works perfect, even with higher bit rates than is specified in the user manual but I'd like to get a 2 or 4 gig card to hold more songs. Just wondering if anyone has tried it before I buy a card that is larger or buy more 1G cards.
Thanks
Username: Psychedelic_feta
Montreal, Quebec
Post Number: 17
Hey Don, I took the risk...you can go up to 4 gigs!! I tried it and it worked.
The reason why it t says the maximum supported size is 1 gig, its cuz that was the largest sd card size you could get when the unit came out on the market, since then, you can now buy up to 4GB...Someone even told me they have 8 gig SD cards by now...
Home > Message Board > Car Audio > Multimedia Systems > Archive through November 18, 2006 > Sd CARD SIZE FOR jENSEN 9511ts [ « Previous ] [ Next » ]
