Thread: Setting up 2 subwoofers to a 4 channel amp |
New member Username: Castaway21
Post Number: 1 Registered: May-04
| Posted on Thursday, May 06, 2004 - 05:40 pm: |
I am very curious how to properly have my system installed. I am unsure how to properly install my 2 subs with my 4 channel amp. I know i should have a two channel but i was given this 4 channel,b ut what do i do? how do i get the best sound. |
Bronze Member Username: Panache
Brenham,
TX
US
Post Number: 44 Registered: Apr-04
| Posted on Thursday, May 06, 2004 - 06:59 pm: |
Yeah, and whats the difference other than 1 has 2 chans and the other has 4? |
New member Username: Warrior
Post Number: 7 Registered: Apr-04
| Posted on Thursday, May 06, 2004 - 07:54 pm: |
ok first of all what kind of amp is it a and how many watts is it? second what kind of subs are they and how many watts are they? tell me that and i can tell you a way to do it. |
Post Number: 2 Registered: May-04
| Posted on Thursday, May 06, 2004 - 09:46 pm: |
its a 900w Rockford fosgate and its two 10" punch Z's both 400watts. (4 Ohms 1.5: voice coil |
| Posted on Thursday, May 06, 2004 - 10:05 pm: |
you should run them on the 3rd and 4th channels and turn the amp down so you don't blow your subs. |
