Thread: Car audio in home???? |
| Posted on Thursday, May 06, 2004 - 03:22 pm: |
Is there any way to hook up car subs and a car amp in your house. If so can someone help me. Any help would be highly appreciated. |
NorthWest,
Michigan
Post Number: 2739 Registered: Dec-03
| Posted on Thursday, May 06, 2004 - 05:12 pm: |
no good way, no. it can be done, but the results pretty much suck, and it's expensive. better off just going to eBay and buying a used home subwoofer for $150
| Posted on Thursday, May 06, 2004 - 05:22 pm: |
yeah thats what I thought. Would a home reveiver running at 8 ohms work with a jl w0. On the jl website it said the w0 can be run at either 4 or 8 ohms. Will this work. thanks
| Posted on Thursday, May 06, 2004 - 08:33 pm: |
JL makes a 8ohm W0 and a 4 ohm w0 get a 8ohm and it will work. go to this site and look at the JL W0-8 they have them at a pretty good price. http://www.acaraudio.com/default.php?cPath=24_48&sort=2a&page=3 |
| Posted on Thursday, May 06, 2004 - 09:39 pm: |
thanks alot for your help |
