Thread: Power acoustik amp |
New member Username: Zippitta
Mulberry,
Florida
United State...
Post Number: 4 Registered: Apr-04
| Posted on Thursday, May 06, 2004 - 09:47 am: |
I was looking at some of the power acoustik amps (primarily the lt 1920) It is advertised to be 440 x 2 @ 2 ohms RMS and 880 mono RMS... but there only like $200. Are these specs accurate or are they extremely over rated? |
Bronze Member Username: Southernrebel
Louisiana
Post Number: 64 Registered: Mar-04
| Posted on Thursday, May 06, 2004 - 12:40 pm: |
....sounds very over rated.... what size fuses does the amp have??? |
Mulberry,
Florida
United State...
Post Number: 5 Registered: Apr-04
| Posted on Thursday, May 06, 2004 - 01:22 pm: |
I have no clue but you can look at the specs at www.justamps.com...they have the same exact specs as on the official site. |
| Posted on Thursday, May 06, 2004 - 08:04 pm: |
man don't waste your money on that piece of junk try a kicker are jbl. that thing is so cheap because it is over rated and you will not get very good sound out of it. |
