Thread: No Audio with CDs DVD or TV on Jensen VM9511TS |
New member Username: Dchap
Pittsford,
New York
Post Number: 1 Registered: Sep-06
| Posted on Wednesday, September 27, 2006 - 09:38 pm: |
I am going nuts. I have installed many a car stereo in my day. I purchased a Jensen VM9511TS Multimedia receiver yesterday. The first one I bought had no sound when playing a DVD and the DVD picture was jerky so I took it back and exchanged it. Hooked up the new one. DVD picture is fine. BUT I get no sound at all when trying to play a CD, DVD or the TV. The radio plays fine and sounds great! The brown Mute wire is not connected to anything. I can't believe I would need an external Amp just for the CD, DVD and TV. Have not tried an SD card yet.. Any ideas? Like I said, the radio is fine so it cannot be wiring. Thanks |
Gold Member Username: Tjmutlow
Post Number: 2853 Registered: Sep-05
| Posted on Thursday, September 28, 2006 - 07:06 am: |
does the radio work if so the power antenna is hooked up instead instead of amp turn on wire. |
Pittsford,
New York
Post Number: 2 Registered: Sep-06
| Posted on Thursday, September 28, 2006 - 07:39 am: |
The radio works and the blue wire is hooked up to the power antenna - it works. I do not have an external amplifier and am not using the pre-amp outputs. The blue stripe amplifier power wire is not hooked up to anything. Are you saying that this unit requires an external amp? Makes no sense. Thanks |
New member Username: Mattyb777
Post Number: 7 Registered: Mar-06
| Posted on Thursday, September 28, 2006 - 10:37 am: |
Try hooking up the remote-on wire also. I believe I had to when hooking up my vm9510ts. |
Silver Member Username: Makmillion
MN
United States
Post Number: 698 Registered: Apr-06
| Posted on Friday, September 29, 2006 - 03:53 am: |
bad unit, exchange it. |
Pittsford,
New York
Post Number: 3 Registered: Sep-06
| Posted on Friday, September 29, 2006 - 04:49 am: |
I did a bit more research on my car. Apparently it has a factory Amp - Infinity Sound. It is a 2000 Sebring Conv. JXI.. So I switch the blue wires, removing the Power Antenna and moving it to the external amp feed and voila! Everything is working perfectly. Thanks fo rall the comments. |
MN
United States
Post Number: 701 Registered: Apr-06
| Posted on Friday, September 29, 2006 - 05:34 am: |
Weird.. I've had about 30 of those jensens come back with no audio on the dvd player, lol! You lucked out brother!  |
