Thread: Whats a good equalizer???? |
Silver Member Username: Tdawg30
Ohio
Post Number: 232 Registered: Jun-06
| Posted on Tuesday, September 26, 2006 - 09:00 pm: |
I have a jvc kd ar760 and was wondering what a good equalizer would be to match this??? can anyone suggest me some cd player/equalizer combos for around 300 bucks or so. |
Gold Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 3094 Registered: Feb-05
| Posted on Wednesday, September 27, 2006 - 12:57 am: |
depends on how many bands you want. most CD players with built in EQ's have between 5 and 16 bands. seperate EQ's have up to 32 bands. Audiocontrol makes some good stuff, not sure on prices though. |
Ohio
Post Number: 235 Registered: Jun-06
| Posted on Wednesday, September 27, 2006 - 01:23 am: |
I want idk more lol. so basically whatever add on will be better than what ive got with my built in equalizer....what about like power acoustik and stuff like that???? does it really matter what brand, I want one with a volt booster too. |
Stockbridge,
GA
Post Number: 3104 Registered: Feb-05
| Posted on Wednesday, September 27, 2006 - 01:38 am: |
i wouldn't go with PA for anything. or any other cheap brand like that. spend your money wisely and do it right the first time. look at Audiocontrol, Zapco, i think Arc Audio, Eclipse and Kicker. |
Silver Member Username: Makmillion
MN
United States
Post Number: 654 Registered: Apr-06
| Posted on Wednesday, September 27, 2006 - 03:38 am: |
Eclipse makes the 21010 which bosts 8v preouts, a 6 band EQ and a really nice, detailed sub control I almost bought one but the bidding went higher than I wanted to pay. I believe it's run with one RCA input and 3 sets of outputs rated @ 8v. But you need to make sure your amp(s) can handle 8v inputs |
Stockbridge,
GA
Post Number: 3113 Registered: Feb-05
| Posted on Thursday, September 28, 2006 - 10:16 am: |
8V Eclipse is nice, but 16V Zapco is better  |
MN
United States
Post Number: 695 Registered: Apr-06
| Posted on Friday, September 29, 2006 - 03:06 am: |
16v?! there must be a 30 step sub level/volume on that thing!! |
Stockbridge,
GA
Post Number: 3120 Registered: Feb-05
| Posted on Friday, September 29, 2006 - 05:47 am: |
Zapco Symbilink, check it out, its great. 16V and fully Balanced  |
Gold Member Username: Mixneffect
Orangevale,
Ca.
Post Number: 1096 Registered: Apr-05
| Posted on Friday, September 29, 2006 - 11:54 pm: |
16V ??? Do you have to upgrade your charging system? |
MN
United States
Post Number: 759 Registered: Apr-06
| Posted on Monday, October 02, 2006 - 01:15 am: |
I see it :P It's 16v Max, 9v RMS.. pretty dang sweet! It looks like it's just a line driver, though.. boosts the outputs on a deck from xx to 9v RMS. |
Stockbridge,
GA
Post Number: 3155 Registered: Feb-05
| Posted on Monday, October 02, 2006 - 07:19 am: |
i'm using the SLDIN.T-F Transmitter, not one of thoes add on units. totally different. it balances and boosts the Pre Out Voltage by 6 or 12dB constant. night and day difference! |
Gold Member Username: Tjmutlow
Post Number: 2857 Registered: Sep-05
| Posted on Monday, October 02, 2006 - 07:47 am: |
audiocontrol three.1 |
