Home > Message Board > Car Audio > Security Systems > Archive through November 24, 2006 > Alarm installation
Author Thread: Alarm installation
Username: Tribi
i want to install an alarm on my 94 accord i would like to know if anybody can help me i need the wire colors for the door lock,head light,hazard lights also if the door lock is negative or possitive trigger please help me thank you
Username: Motomaze
Ont
Post Number: 24
always check your wires test them with an multi meter 12v white @ign. ign blk yellow, park lights+ red/blk @blue plug at the fuse box area door pin -blk/white grey plug right of steeering column and door locks are - lock is blk/white
and unlock is orange above fuse box in blue tape
solder and tape all connections
Home > Message Board > Car Audio > Security Systems > Archive through November 24, 2006 > Alarm installation [ « Previous ] [ Next » ]
