Home > Message Board > Car Audio > Speakers > Archive through September 22, 2006 > 4x6's???
Author Thread: 4x6's???
Username: Naledge503
Portland, Oregon
U.S.
Post Number: 244
I am looking to upgrade my stock 4x6's. they are in the dash. my vehicle doesnt have front door speakers. and has 6 1/2 speakers in the back doors. I am looking for something for about $75 and will buy online. also i am planning on buying an amp to power my speakers. any opinions and suggestions will be appreciated.
Username: Chaunb3400
Huntsville, Alabama
U.S.
Post Number: 9118
u looking for 2 sets of speaks???
Portland, Oregon
U.S.
Post Number: 245
nah just the 4x6's. 1 pair. unless you think it would make a difference if i upgrade the back door speakers. you're one of the only people i would take advise from on these forums. so what do you think?
Huntsville, Alabama
U.S.
Post Number: 9126
what kind of vehical is it???
if they make an adapter plate for ur vehical i would buy it and try and fit some 5 1/4 or 6 1/2 insted of the 4x6...imo they dont reproduce sound as clean and crips as a round speak
Portland, Oregon
U.S.
Post Number: 246
its a 94' olds bravada. see i was thinkin about doing 4" or 5" speakers and then adding like 1" tweets but i didnt want to have to do custom work. so if they make adapter plates that would be tight.
Huntsville, Alabama
U.S.
Post Number: 9130
these should work
http://www.crutchfield.com/S-hMNettS0w38/cgi-bin/prodview.asp?i=142SAC656
Huntsville, Alabama
U.S.
Post Number: 9131
i had the same kind of speaks 4x6 in my nephews 99GAGT
and i used the bigger plate and it works perfect
Portland, Oregon
U.S.
Post Number: 247
hell yeah. thanks man. that's what i wanted to do. but i didnt even know they made adapter plates. this should make it a hella lot easier to come up with somehing. i wasnt to thrilled about the whole 4x6 thing. and like i said i didnt want to do any custom work. thanks again.
Huntsville, Alabama
U.S.
Post Number: 9139
no problem good luck!!!
Home > Message Board > Car Audio > Speakers > Archive through September 22, 2006 > 4x6's??? [ « Previous ] [ Next » ]
