Home > Message Board > Car Audio > Head Units > Archive through October 22, 2006 > Aftermarket cd player 03 monte Carlo ...
Author Thread: Aftermarket cd player 03 monte Carlo with ONSTAR
Username: Black013
Post Number: 84
guess this question been asked before but i couldnt find a clear answer can i install a after market cdplayer without buying that 100$ bypass module???? I dont need any onstar controls
Username: Safe_cracker
Chicago, IL
US
Post Number: 1613
Your car came with a CD player, why would you need another or are you asking if you can install an aftermarket Head unit? The answer is yes, the Onstar can be removed, just unplug it and remove. Polo..
Username: Theelfkeeper
Stockbridge, GA
Post Number: 3096
its never impossible to install an aftermarket HU. it can just sometimes get involved in the wireing process. you'll have to look at the wireing and seperate the onstar stuff and only hook up whats necessary for the HU. sometimes a custom dask kit may have to be made too.
Home > Message Board > Car Audio > Head Units > Archive through October 22, 2006 > Aftermarket cd player 03 monte Carlo ... [ « Previous ] [ Next » ]
