Posted on Wednesday, September 20, 2006 - 09:07 pm:
Im about to que this siganl processor but i have a problem. The manual indicates that it has a 3 way cross over for the front, rear and center channels. I want to you the passive cross overs on the set. You can use only the hp and set it as a one way on the 3sixty.2 cross over or you have to use the 3 way? (this setup is only for the fron and rear)
