Home > Message Board > Car Audio > Security Systems > Archive through November 24, 2006 > CLIFFORD CONCEPT 60 HELP WANTED PLEAS...
Author Thread: CLIFFORD CONCEPT 60 HELP WANTED PLEASE ??
Username: G1swx
Weston, Somerset
United kingdom
Hi all,
I have a Clifford concept 60 alarm fitted to my MR2 Turbo. I have the following problems :-
1. I have obtained a spare Clifford Fob from Ebay (Looks the same as mine !!, but inside circuit board is different). I seem to be unable to ADD this Fob to the system using the instructions in the manual.
2. I was trying to programme the alarm the other day to turn off some of the sirens, but when I had finished the system now does the following :-
(a) When alarming/locking the car the indicators flash as normal, but the light now come on for 30 secs then turn off !!
(b) The MR2 has retracting mirrors. Now when I click on the normal key on the fob to retract them, they go in and out several times !!! most amusing for the neighbours.
Canany one help please ??
PS Where can I get an installation guide from ?
Thanks
chris
Home > Message Board > Car Audio > Security Systems > Archive through November 24, 2006 > CLIFFORD CONCEPT 60 HELP WANTED PLEAS... [ « Previous ] [ Next » ]
