Home > Message Board > Car Audio > Multimedia Systems > Archive through November 18, 2006 > Need help got a jesen 9311
Author Thread: Need help got a jesen 9311
Username: Paulyblaze
how do i bypass the the brake i tried just groundin the wire doesnt work i heard u can hook a toggle switch to it how do i do that ????
Username: Kx714
Orlando, Fl
Get a 2 prong switch. Hook the ground side of the switch to a ground (metal surface) and hook the pink wire coming from the head unit to the other prong on the switch. When you want to watch movies with the car on switch it on and off as it says in the manual. Hope it helps.
Username: Jayce2000
Post Number: 10
You cant just ground the PINK wire this year,Jensen added a sequence for the system to work..
EBAY auction for $19.95 I saw which is all text related with no parts needed..Works 100% of the time...
Home > Message Board > Car Audio > Multimedia Systems > Archive through November 18, 2006 > Need help got a jesen 9311 [ « Previous ] [ Next » ]
