Home > Message Board > Car Audio > Multimedia Systems > Archive through November 18, 2006 > Need help got a jesen 9311
Author Thread: Need help got a jesen 9311
Username: Paulyblaze
how do i bypass the the brake i tried just groundin the wire doesnt work i heard u can hook a toggle switch to it how do i do that ????
Username: Jayce2000
Post Number: 15
See the replies for the 9411,9511 and 9021 it wil lbe the same fix...
Username: Evol
Post Number: 7
Follow these Instructions..............
If you look on pg18 (I Think) in the owners manual it will tell you how to activate the DVD. Same thing applies here , Just hook up the pink to a post on the toggle then a ground2body wire to the other post on the toggle .
If the deck is on prior to turning on the ignition flip the switch back and forth 1 time.
If your deck is off when you turn on the ACC>Ignition , simply turn on your deck and flip your toggle back and forth twice to enable DVD.
REMEMBER DVD must be playing at that time or it won't work.
** Im using a 2 post only Toggle switch and 18gauge wire. **
YOUR LOCAL AUTO PARTS STORE SHOULD HAVE CHEAP TOGGLE SWITCH AND WIRE THAT YOU WILL NEED.
If you still need more help let me know...
Home > Message Board > Car Audio > Multimedia Systems > Archive through November 18, 2006 > Need help got a jesen 9311 [ « Previous ] [ Next » ]
