Home > Message Board > Car Audio > Speakers > Archive through September 22, 2006 > HELP ME GET SOME GOOD SPEAKERS FOR MY...
Author Thread: HELP ME GET SOME GOOD SPEAKERS FOR MY CAR!!!!!!!!!!!!!!!!!!!!!!!
Username: Avirex64
Vallejo, CA
Post Number: 8
I dont really know to much about car audio, what are some good speakers? I heard infinity were good is this true? what do you guys think?????
Username: Ctmike
Ct.
Post Number: 1763
what's your budget for speakers and amp (i assume your getting one)? also, you looking at a component set, if so pm alteraudio and he'll hook you up with some cdt's, he's always hooking members up with special prices.
Username: Alteraudiousa
Concord
Post Number: 1245
what kind of car?
Username: Avirex64
Vallejo, CA
Post Number: 9
I dont really have a budget, I jus want it to soung good, I have 2 15' MTX 8500's so they would have to be sumthing loud. Its a 01 Buick Century
Username: Avirex64
Vallejo, CA
Post Number: 10
Do you have any suggestions?
Username: Theelfkeeper
Stockbridge, GA
Post Number: 2960
so is that you don't really have a budget but want to keep it cheap or don't really have a budget and have plenty to spend??
are we talking coaxials or components, HU power or Amp power...
$300, $500, $700, $1000....
Username: Avirex64
Vallejo, CA
Post Number: 11
I dont have a budget and have plenty to spend, I just want it to sound crisp and clear and able to be very loud. I dont really know what the difference is betwen coaxials or components, which do you think is better?
Stockbridge, GA
Post Number: 2964
well if you are going to power the speakers with plenty of power, like 75 to 200 Watts RMS, then components will take full advantage of the power and give you the best results.
if just using HU power, coaxials are best because components need more power.
the difference is coaxials have the tweeter mounted on a pole in the center of the woofer with a simple capacitor as a crossover. they are basically stock replacements, not really giving you that much increase in SQ.
components have a seperate woofer and tweeter with a higher quality external passive crossover. larger and higher quality components means they will handle more power and usually there will be a coupld options for adjustment on the crossovers. and having the drivers seperate gives you more flexability on how and where you can install them to give you the best results.
cons for components are just that they require a little more in the install because you have more to find room for.
Username: Avirex64
Vallejo, CA
Post Number: 12
ok, yes I think I will go with components. What are some good brands?
Username: Logan__tille
Hamilton, Indiana
United states
Post Number: 990
what size?
Hamilton, Indiana
United states
Post Number: 992
what size?
Concord
Post Number: 1253
4 or 6 speakers?
I believe its 5.25 up front and 6x9 in the rear.
First you need an amp to run atleast the fronts. Rears can be run off deck power.
I don't know the depth of the doors but HD-52 in the front with an amp that puts out like 150x2rms would be good and Kenwood Excelon 6x9 in the rear.
Username: Avirex64
Vallejo, CA
Post Number: 14
which is better? 4 or 6?
Concord
Post Number: 1255
no thats how many your car can have. It depends on the model Century.
Username: Avirex64
Vallejo, CA
Post Number: 17
oh i think it only has 4
Username: Avirex64
Vallejo, CA
Post Number: 18
and 2 tweets
Username: Makmillion
MN
United States
Post Number: 531
So 6.
Username: Avirex64
Vallejo, CA
Post Number: 19
yea
Username: Dht
Guadalajara, Jalisco
Mexico
Post Number: 51
morel,rainbow, dls, hertz, seas, dynaudio,scanpeak, genesis. this are some good brands, the model depends on your budght and needs.
Username: Avirex64
Vallejo, CA
Post Number: 29
I dont have a budget, I just need something good
Username: Noviceinstaller
Here, There
Post Number: 97
off the subject but avirex are da bomb diggetty
Username: Avirex64
Vallejo, CA
United States
Post Number: 44
anyone have anymore suggestions on brands?
Username: Bernymac
Rialto, CA
United States
Post Number: 260
everyone gave you good suggestions already, no where else to look really. just consider the brands they told you.
Home > Message Board > Car Audio > Speakers > Archive through September 22, 2006 > HELP ME GET SOME GOOD SPEAKERS FOR MY... [ « Previous ] [ Next » ]
