Thread: Need help with Components and amp selection |
New member Username: Matt_dobb
Post Number: 2 Registered: Sep-06
| Posted on Wednesday, September 13, 2006 - 05:48 pm: |
I am up in the air on which set of components to get it's between these 5 models. Focal 165K2P, CDT ES-620 or Gold HD-62 Gold and DLS Iridium 6.2 or Nobelium 6.2. My biggest concern right now is not having enough power to run these. I have a 300/4 that I can bridge to 150 x 2 rms but then I will need another amp for the rear midbass's :-| I am not totally against another amp just was hoping to get it done with this amp. If anyone thinks this amp is not powerful enough to run these please say so. Also what would be your pick out of the 5 models spec'd? |
Post Number: 3 Registered: Sep-06
| Posted on Wednesday, September 13, 2006 - 09:06 pm: |
No one has any opinions? |
Silver Member Username: Makmillion
MN
United States
Post Number: 422 Registered: Apr-06
| Posted on Thursday, September 14, 2006 - 01:50 am: |
I'd go with Focal 165K2P They're really nice speakers.. |
Silver Member Username: Dkchillin
Vermont
Post Number: 283 Registered: Mar-05
| Posted on Thursday, September 14, 2006 - 05:38 am: |
I also think the Focals would be a good choice and if it were me, I wouldn't worry about amping the rear speakers, especially if you're running subs. |
Post Number: 4 Registered: Sep-06
| Posted on Thursday, September 14, 2006 - 08:25 am: |
I listen to all music not just one type, 50% of the time it's Hip Hop then classic rock would follow with about 25% and then the last 25% would be everything else. With that being said would the focal's tweeters be over barring for extended periods of time? |
Gold Member Username: Alteraudiousa
Concord
Post Number: 1234 Registered: Jan-06
| Posted on Thursday, September 14, 2006 - 08:34 am: |
I like the DLS and the CDT HD-62/M6. DLS was very solid all the way around and for me has an easier tweeter to listen to than the Focals. As for the CDT's, I love their tweeters and the M6 driver is quite nice but they require tons of power. |
Post Number: 5 Registered: Sep-06
| Posted on Thursday, September 14, 2006 - 09:05 am: |
That's my biggest issue with the CDT's is that they do require so much power. I was wanting to keep things simple but sound really nice. So between the 2 different pairs of DLS (Nobelium & Iridium) what's the biggest noticeable difference? |
Gold Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 2941 Registered: Feb-05
| Posted on Thursday, September 14, 2006 - 06:24 pm: |
wheres the Rainbows?? CDT HD's are nice, i ran a 3 way set off a JL 300/2, worked fine. ES's aren't worth the extra money over the HD's imo, but Alter may be able to work you a deal on CDT stuff. Iridiums are install picky but very nice. no idea on the Nobelium's, haven't heard much about them yet. Focals are nice, but tweeters are hard to tame. |
Silver Member Username: Spidercoder
Palm Harbor,
Florida
Post Number: 107 Registered: Aug-06
| Posted on Friday, September 15, 2006 - 03:42 pm: |
I would go with the Diamond Hex S600s.Compare the quality of the crossovers from them and the CDTS is like night and day. CDT uses cheap parts in thier crossovers. The Diamonds are by far in a whole different league than the cdt. |
Concord
Post Number: 1239 Registered: Jan-06
| Posted on Friday, September 15, 2006 - 05:24 pm: |
and what crossovers are you comparing? |
Palm Harbor,
Florida
Post Number: 113 Registered: Aug-06
| Posted on Friday, September 15, 2006 - 06:31 pm: |
You can compare any crossover cdt makes to the diamond hex crossover major difference in quality. Of course you will come on and stick up for cdt you deal them your biased. Diamond is much better quality than CDT by far hands down. Take cdt top of line take diamond d971 no comparison Diamond makes better componets, subs and amps than cdt. Not even in the same league. |
Concord
Post Number: 1240 Registered: Jan-06
| Posted on Saturday, September 16, 2006 - 12:19 am: |
lol, you're pretty judgemental and biased in your own right. And no i'm not biased I just asked which ones you ACTUALLY have looked at and how you would go and compare them. I've used Diamond D7 and D5 and Hex stuff and its all very well made, not too impressed with the amps as I prefer an ARPA built amp and the sub is only so so as my Mag will destroy them, but to each his own. |
