Home > Message Board > Car Audio > Speakers > Archive through September 22, 2006 > Re-Hooking UnHooked SPeakers in 89 Camry
Author Thread: Re-Hooking UnHooked SPeakers in 89 Camry
Username: Vintagekobe
So I got an 89 Camry and I tried re hooking the Back speakers taht everyone told me where unhooked. And I had no Succsess I opened up the part wehre the Radio is and took out the Radio and everything and did not understand anything there, ONly thing I remembenr is I took some thing out and it woudl turn off the radio and when I put it back on the radio would continue playing.
So any help would be great I just want my back speakers to be working again.
Username: Makmillion
MN
United States
Post Number: 377
More details, please.
What was the original situation....?
They have Never Been working, Is my guess, but everyone I have asked has said They have been unhooked.
MN
United States
Post Number: 385
have you checked to see that they are plugged in on the rear of the speaker?
Yeah, They are plugged in on the rear.
Username: Jenifer_contreras
Tampa, Florida
Post Number: 319
Kobe,I got an idea,look at this schema and reconnect rear speakers to the front(speakers) outlet.If it start to work then it the HU problem!If not then it wiring problem...check out all pins inside and out of the plug.It's old car,maybe some wire rosted and fell off!
application/x-zip-compressedUpload
1989 toyta camry.zip (35.9 k)
Username: Kaerfpl
Spencerport, NY
Post Number: 401
Do you have a factory stereo or an aftermarket HU?
Home > Message Board > Car Audio > Speakers > Archive through September 22, 2006 > Re-Hooking UnHooked SPeakers in 89 Camry [ « Previous ] [ Next » ]
