Thread: Polk MMC570 vs JL XR570-CXi Coaxials --- Advice requested. |
New member Username: Bleeder
Jville,
Fl
US of A
Post Number: 9 Registered: Mar-06
| Posted on Friday, September 08, 2006 - 04:39 am: |
I have a 2005 Ford F-250 Crew with Factory Speakers (Stock 5 1/4" up front, 5" X 7"'s in the rear) and was thinking of a mid-range (or slightly higher) set of coaxial speakers to upgrade to. I want to try NOT to mod the doorpanels, but simply purchase a set of drop-ins that will fit the existing slot. My HU is the Pioneer DEH-P880PRS, but will be eventually get an amp this fall (looking at the JL 300/2 or 300/4). I'll likely purchase the respective front 5 1/4" speakers once I decide on which company my hard-earned dollars are going to... The specs seem similar regarding the Polk MMC570 vs JL XR570-CXi Coaxials, but I'm still torn --- I'm trying to decide if I should pony-up the extra green for the JL's? I'm sure there are other speakers I should be considering, and I will appreciate other options, but these are locally available at a discount with full warranty. Any help in the decision-making will be greatly appreciated. Opinions??? |
Silver Member Username: Delsole
Post Number: 843 Registered: Feb-05
| Posted on Friday, September 08, 2006 - 06:21 am: |
im sure you would be happy with the jl's . but there are alot more possibilities o here everyone elses side to |
Gold Member Username: Alteraudiousa
Concord
Post Number: 1212 Registered: Jan-06
| Posted on Friday, September 08, 2006 - 10:03 am: |
5X7 THERE AREN'T AS MANY AS A 6.5 OR 5.25. XR'S ARE GREAT COAXS FOR YOU AND I LIKE THEM BETTER THAN THE MOMO'S. VERY GOOD ALL ROUND SET. |
