Thread: Is it common for crossovers for componets to be installed |
Bronze Member Username: Spidercoder
Palm Harbor,
Florida
Post Number: 99 Registered: Aug-06
| Posted on Thursday, September 07, 2006 - 10:05 pm: |
behind the head unit? |
Silver Member Username: Kklagge
Post Number: 317 Registered: Dec-04
| Posted on Friday, September 08, 2006 - 06:30 am: |
I suppose if you're running the comps off the HU then that might be an ideal spot....you must have a lot of room behind your HU, huh? I could barely get an extra wire behind mine. |
Silver Member Username: Spidercoder
Palm Harbor,
Florida
Post Number: 103 Registered: Aug-06
| Posted on Friday, September 08, 2006 - 08:12 am: |
no they are being ran off of an amp. Shouldnt the crossovers be closer to the drivers and not behind the HU. |
Gold Member Username: Alteraudiousa
Concord
Post Number: 1213 Registered: Jan-06
| Posted on Friday, September 08, 2006 - 10:06 am: |
no not at all. unless they ran the wires for the components back behind the radio its not normal at all. crossovers are normally wired close to the speaker for one reason, less wire to run through the door jams. Its quite odd and i'd ask whoever did it why and have them show you how they went about doing it. |
Gold Member Username: Invain
Michigan
United States
Post Number: 4124 Registered: Aug-04
| Posted on Friday, September 08, 2006 - 12:26 pm: |
It doesn't really matter. Put them where convenient. |
Silver Member Username: Justblaze
St.Louis,
MO
Post Number: 139 Registered: Jun-06
| Posted on Sunday, September 10, 2006 - 12:44 pm: |
yeah, i actually mounted mine on my doors so i could adjust the tweeter level without having to take anything apart. works for me. |
