Thread: What's a good component set between $200-$300? |
Bronze Member Username: Camarobump
Post Number: 12 Registered: Sep-06
| Posted on Tuesday, September 05, 2006 - 11:48 pm: |
I have a 1997 Camaro with all of the factory door speakers still in there. The 2 front and 2 back speakers are 6.5"s, and the 2 trunk speakers I believe are 3" tweeters. I want to upgrade to something with crisp, clean sound but can get loud when turned up. |
Gold Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 2802 Registered: Feb-05
| Posted on Wednesday, September 06, 2006 - 01:06 am: |
nothing will sound crisp or clean when you turn it up without an external amplifier. do you plan on getting an amp for the speakers?? |
Post Number: 15 Registered: Sep-06
| Posted on Wednesday, September 06, 2006 - 01:39 pm: |
Yeah, could you suggest some amps that would be good for this purpose. I have a urban 300w amp now that I am using for my subs, but I am about to upgrade to a better amp for those. Do you think this amp would be good to use on the the component speakers? |
Silver Member Username: Delsole
Post Number: 797 Registered: Feb-05
| Posted on Wednesday, September 06, 2006 - 05:24 pm: |
i think 2 sets of 6.5's and a set of tweets plus an amp will cost more then 300 bills |
Silver Member Username: Jenifer_contreras
Tampa,
Florida
Post Number: 217 Registered: Jul-06
| Posted on Wednesday, September 06, 2006 - 07:35 pm: |
you can start with the infinity component speakers and amp KENWOOD XXV-02A, all together~300$ from e-bay! |
Post Number: 807 Registered: Feb-05
| Posted on Wednesday, September 06, 2006 - 08:30 pm: |
kenwood sucks balls |
Silver Member Username: Adddisorder
West palm,
Florida
Post Number: 763 Registered: Jan-06
| Posted on Wednesday, September 06, 2006 - 09:05 pm: |
so do infinity componets or atleast the reference |
Post Number: 815 Registered: Feb-05
| Posted on Wednesday, September 06, 2006 - 09:29 pm: |
ya please dont take it the wrong way cuz of what i said jenifer in my eyes they arent very good, k baby |
Gold Member Username: Alteraudiousa
Concord
Post Number: 1207 Registered: Jan-06
| Posted on Wednesday, September 06, 2006 - 11:10 pm: |
I would worry only about the front door speakers and the middle ones. Your sub in the back is all you need for the rear. I would suggest a good component set up front and the middles get some coax's for rear fill. If you'd like some CDT components, message me and i'll get you them. |
Post Number: 16 Registered: Sep-06
Are Alpine component speakers worth putting in my Camaro? |
Concord
Post Number: 1208 Registered: Jan-06
| Posted on Wednesday, September 06, 2006 - 11:23 pm: |
i don't like them but if you must get them only get the Type R or X |
Post Number: 17 Registered: Sep-06
| Posted on Wednesday, September 06, 2006 - 11:28 pm: |
what would you prefer putting in there? |
