Thread: Can anyone help me here??? |
Bronze Member Username: Drm035
Darlington,
SC
Post Number: 29 Registered: Jul-06
| Posted on Monday, September 04, 2006 - 10:19 pm: |
I need to find a wiring diagram for a 97 ford taurus to add a cd changer. Having trouble finding the antenna plug! |
Silver Member Username: Bobimpact
Danbury,
CT
US
Post Number: 112 Registered: May-06
| Posted on Monday, September 04, 2006 - 10:33 pm: |
The antenna plug on that car is in the trunk behind the left side panel, it is connected to the tuner/radio box. It uses a Ford Antenna Adaptor. I believe Metra sells an extension cable that will give you enough length to get behind the radio/climate control bezel. |
Darlington,
SC
Post Number: 30 Registered: Jul-06
| Posted on Tuesday, September 05, 2006 - 01:26 pm: |
Thank you for your help. |
Darlington,
SC
Post Number: 31 Registered: Jul-06
| Posted on Tuesday, September 05, 2006 - 01:33 pm: |
Thank you for your help. I will let the guy know.. |
