Home > Message Board > Car Audio > Speakers > Archive through September 22, 2006 > Ohm Load question
Author Thread: Ohm Load question
Username: Spidercoder
Post Number: 46
On a 4 channel amp if I was running a set 0f 4 ohm speakers to channels 1 and two what would be the ohm load to the amp would it be 4 or 2 ohms Im thinking it would be 4 ohms because its just a single speaker to each channel with a 4 ohm load. But am I wrong.
Thanks
Username: Adddisorder
West palm, Florida
Post Number: 742
your right
Username: Theelfkeeper
Stockbridge, GA
Post Number: 2767
the load goes per channel/output. on channels 1 and 2, you will have a 4 ohm load. theres no total over all load if thats what your asking.
Post Number: 47
thanks that was what i thought
Home > Message Board > Car Audio > Speakers > Archive through September 22, 2006 > Ohm Load question [ « Previous ] [ Next » ]
