Thread: 6x9 to 6.5 |
Bronze Member Username: Lowfront
Post Number: 86 Registered: Jun-05
| Posted on Monday, August 28, 2006 - 10:33 am: |
Alright now I was told that 6.5 will sound better then 6x9. But I can't seem to find an easy way to put 6.5 into 6x9 without going through a headache trying to get it to work. Should I really do it, or just some 6x9's? If I should just get 6x9's can you recommend me some from www.woofersetc.com |
Gold Member Username: Alteraudiousa
Concord
Post Number: 1171 Registered: Jan-06
| Posted on Monday, August 28, 2006 - 11:03 am: |
you need an aapter plate which is like 15$ to make it work. Not that hard really. If you're using a 6x9 for rear fill its ok, but if its like a truck with 6x9 up front i'd say switch them. As for woofersetc.com If you are looking for CDT products I can help you out. I also can get Kenwood Excelon and JL. And it will all be under warranty also. Also do you want coxials which you'd run off the HU or components? |
Post Number: 91 Registered: Jun-05
| Posted on Monday, August 28, 2006 - 11:48 am: |
its for the rear..Idk where could I find an adapter... |
Post Number: 92 Registered: Jun-05
| Posted on Monday, August 28, 2006 - 11:52 am: |
http://cgi.ebay.com/Scosche-SA69-6x9-to-5-25-and-6-5-speaker-adapters_W0QQitemZ2 30022092486QQihZ013QQcategoryZ60208QQssPageNameZWD1VQQrdZ1QQcmdZViewItem would that work...it says 5.25 or 6.5.... Does that mean either will work no problem or I need to request one or the other? |
Silver Member Username: Adddisorder
West palm,
Florida
Post Number: 661 Registered: Jan-06
| Posted on Monday, August 28, 2006 - 02:13 pm: |
look online for an adapter or build one out of plywood/mdf thats what i did |
Concord
Post Number: 1174 Registered: Jan-06
| Posted on Monday, August 28, 2006 - 02:50 pm: |
I can get you adapter plates if you order from me, you can find them at almost any shop. |
Post Number: 96 Registered: Jun-05
| Posted on Monday, August 28, 2006 - 05:30 pm: |
are these speakers any good for fillers in the back? |
Post Number: 97 Registered: Jun-05
| Posted on Monday, August 28, 2006 - 05:31 pm: |
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3365 |
West palm,
Florida
Post Number: 671 Registered: Jan-06
| Posted on Monday, August 28, 2006 - 09:15 pm: |
http://www.wickedcases.com/caraudio/rearfill.html id just take that money and put it to a better pair for hte front |
Concord
Post Number: 1176 Registered: Jan-06
| Posted on Monday, August 28, 2006 - 09:24 pm: |
they excel in the mids and highs but not midbass. What is going up front? |
Silver Member Username: Lowfront
Post Number: 106 Registered: Jun-05
| Posted on Tuesday, August 29, 2006 - 02:30 am: |
these were gonna go in the front |
Post Number: 107 Registered: Jun-05
| Posted on Tuesday, August 29, 2006 - 02:31 am: |
these were gonna go in the front http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3080 |
Post Number: 108 Registered: Jun-05
| Posted on Tuesday, August 29, 2006 - 03:31 am: |
these were gonna go in the front http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3080 this is very interesting read...should I just not use the back speakers then? Sounds fine to me think ill go with these in the front now, although my amp is only 250watts these are 140rms is that alright? http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3341 |
Concord
Post Number: 1180 Registered: Jan-06
| Posted on Tuesday, August 29, 2006 - 10:46 am: |
If you want a better deal still under warranty since I'm a dealer also, for 225$ I can get the EF-61CF with upgraded 560crossover on it and the tw-25T tweeter. This needs to be ordered by the end of the month for it so act fast. Woofersetc.com is good but why use them when you have a dealer on here. |
Post Number: 109 Registered: Jun-05
| Posted on Tuesday, August 29, 2006 - 01:02 pm: |
Alright I'll do that |
Post Number: 113 Registered: Jun-05
| Posted on Tuesday, August 29, 2006 - 02:00 pm: |
let me get free shipping |
Post Number: 114 Registered: Jun-05
| Posted on Tuesday, August 29, 2006 - 02:14 pm: |
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=449 the thing is though is I bought this amp...it says 80x2 250 for one will this work with Power handling: 130 watt RMS |
Concord
Post Number: 1186 Registered: Jan-06
| Posted on Tuesday, August 29, 2006 - 04:23 pm: |
my prices are typically lower than wooferetc anyways. 80rms will be ok but not the best, you'll notice a difference with more power. |
Post Number: 116 Registered: Jun-05
| Posted on Tuesday, August 29, 2006 - 09:53 pm: |
Alright well I'll do that deal with the upgrades I'll just get a diffrent amp mabe the seller will let me cancel order. O well |
Post Number: 123 Registered: Jun-05
| Posted on Wednesday, August 30, 2006 - 08:48 pm: |
You offer a deal then you dissapear... I hope I can get these tomorrow |
Concord
Post Number: 1189 Registered: Jan-06
| Posted on Wednesday, August 30, 2006 - 10:36 pm: |
no i'm still here you can always PM me which comes to my emails. |
Concord
Post Number: 1190 Registered: Jan-06
| Posted on Wednesday, August 30, 2006 - 10:38 pm: |
for some reason your email doesn't accept emails anymore lowfront. |
Silver Member Username: Gangstafert
Jacksonville,
Florida
Post Number: 294 Registered: May-06
| Posted on Wednesday, August 30, 2006 - 11:03 pm: |
Alter im going to go with kick panels in my cutlass can you email me so we can talk about speaker options. Thanx |
Post Number: 124 Registered: Jun-05
| Posted on Thursday, August 31, 2006 - 08:00 am: |
Fixed the email issue sorry about that |
