Thread: NEW Componet System??? |
Silver Member Username: Freezeman_7
Post Number: 160 Registered: May-06
| Posted on Sunday, August 27, 2006 - 06:24 pm: |
i need some suggestions i want to spend no more than 300 dollars on one set. since i already have one set of kappas. they will be run of a alpine v-power 50x4 @4ohms rms. thanks for the advice |
Gold Member Username: Suleman36
Maryland
U.S.A.
Post Number: 4022 Registered: Feb-05
| Posted on Sunday, August 27, 2006 - 09:28 pm: |
I whould go with these : http://www.ikesound.com/product-product_id/982 |
Post Number: 161 Registered: May-06
| Posted on Sunday, August 27, 2006 - 09:34 pm: |
they have to 5x7's or 6x8's i know thats like the same thing but thats what they have to be. |
Gold Member Username: Illuminator
Post Number: 4555 Registered: Apr-05
| Posted on Monday, August 28, 2006 - 02:06 pm: |
http://cgi.ebay.com/JL-AUDIO-XR570-CSi-5x7-6X8-COMPONENT-SPEAKER-SET-NEW-05_W0QQ itemZ270021687825QQihZ017QQcategoryZ18800QQssPageNameZWDVWQQrdZ1QQcmdZViewItem That's about the best you're going to get with 5x7's and a $300 budget. If you're really crazy, you could get these: http://cgi.ebay.com/JL-AUDIO-ZR570-CSI-5X7-2-WAY-COMPONENT-SPEAKER-SET-NEW_W0QQi temZ270022271056QQihZ017QQcategoryZ18800QQssPageNameZWDVWQQrdZ1QQcmdZViewItem But I would prefer to put some 6.5's in the front door at that point, not to mention a better amp. |
Silver Member Username: Adddisorder
West palm,
Florida
Post Number: 660 Registered: Jan-06
| Posted on Monday, August 28, 2006 - 02:12 pm: |
alpine type R's |
Post Number: 4558 Registered: Apr-05
| Posted on Monday, August 28, 2006 - 02:15 pm: |
For his price range, Alpine's wouldn't be the ideal way to go, the JL's would sound much better. |
Gold Member Username: Alteraudiousa
Concord
Post Number: 1173 Registered: Jan-06
| Posted on Monday, August 28, 2006 - 02:49 pm: |
Yeah the JL's are quite nice either component or coax. I'd go with them or the Kenwood Excelon's but they're only coax. I can get you JL if you'd like. |
Post Number: 162 Registered: May-06
| Posted on Monday, August 28, 2006 - 06:04 pm: |
thanks guys but my friend at best buy just ordered me some new Kappa's with 100 rms. and i liked my old kappas anyways. but im gonna make this set is hookd up right |
Post Number: 163 Registered: May-06
| Posted on Monday, August 28, 2006 - 06:39 pm: |
actually. alter can you get the JL Audio ZR570-CSI 5x7 two ways? those look nice. all they any better than the infinitys... i would like a set of those. what can you get me them for???? need to know kinda quick |
Post Number: 165 Registered: May-06
| Posted on Monday, August 28, 2006 - 06:47 pm: |
i guess i could get an adapter plate and put some 6.5's in the front? how much harder owuld that be. cause in my truck i have a factory place for the tweeter right above the reg. mount. i have an 04 f150. if the 6.5's will sound better lets go with them..!!!! |
Bronze Member Username: Spidercoder
Post Number: 28 Registered: Aug-06
| Posted on Monday, August 28, 2006 - 09:03 pm: |
What About CDT Audio |
Concord
Post Number: 1177 Registered: Jan-06
| Posted on Monday, August 28, 2006 - 09:26 pm: |
CDT has no 5x7 they only do the normal sizes so 4x6, 5x7 and 6x8 are all out. But they are much nicer than Infinity, even the Perfects. I never cared for INfinity, major let down for me. |
Post Number: 166 Registered: May-06
| Posted on Monday, August 28, 2006 - 10:04 pm: |
whatever you all think is best. if i can fit 6.5's in ill do that... but if not i think i was those jl's that i specified above. alter you think you can get those to me b4 saturday morning??? |
Concord
Post Number: 1182 Registered: Jan-06
| Posted on Tuesday, August 29, 2006 - 04:20 pm: |
a 6x8 opening can't fit a 6.5 in there nicely, lot of work to get it in. Where you live. I can see about the JL for you. |
Silver Member Username: Justblaze
St.Louis,
MO
Post Number: 132 Registered: Jun-06
| Posted on Tuesday, August 29, 2006 - 09:23 pm: |
they make adapter plates for a 6x8 to a 6.5...ill try to find the link for you |
St.Louis,
MO
Post Number: 133 Registered: Jun-06
| Posted on Tuesday, August 29, 2006 - 09:27 pm: |
http://www.autotoys.com/x/cust/home.php?cat=271 |
Concord
Post Number: 1188 Registered: Jan-06
| Posted on Tuesday, August 29, 2006 - 09:49 pm: |
if you go with the XR or HD 6.5 I doubt that will fit as they are 6.75in drivers. |
