Thread: Audiocontrol 6XS Should i install it??? |
Bronze Member Username: Quick94gt
Fontana,
Ca.
United states
Post Number: 31 Registered: Jul-05
| Posted on Sunday, August 27, 2006 - 05:14 pm: |
my system consists of: Pioneer DEH-P860MP, Alpine Type R 5x7's front and back, Directed 1100D sub amp, Directed 2400 for the highs, and 2 12" Alpine Type R's for the bass, my friend gave me this audiocontrol 6XS free and told me it would improve my sound quality...is this true? how will it improve SQ??? is it worth installing? will i notice a differece? is it better than the 13 band graphic EQ in my Pioneer? |
Relevant Product Info
Fontana,
Ca.
United states
Post Number: 32 Registered: Jul-05
| Posted on Sunday, August 27, 2006 - 05:15 pm: |
sorry it's a 4200 Directed for the highs. |
Gold Member Username: Rovin
Trinidad & T...
Post Number: 9513 Registered: Jul-05
| Posted on Tuesday, October 24, 2006 - 01:45 am: |
if u got it 4 free man then hook it up & try it out ....... |
Gold Member Username: Bestmankind
BTL USA
Post Number: 6488 Registered: Oct-05
| Posted on Tuesday, October 24, 2006 - 12:21 pm: |
do you know how the 6xs works? the front channel has 2 outputs. front high is 250hz and up and the low is 90hz-250hz. you would need a woofer upfront to cover the 90-250hz cause if you don't you will be missing that freq in your system. this is what i did. i changed the 250hz and up chip to 3500hz for the tweeter. that made the front low pass to play 90hz - 3500hz which is good for my mid. you would need to amp the tweeter and the woofer separately and not use the xover that came with your comps. |
