Thread: Problem With My Speakers... |
New member Username: Sean119757
Post Number: 1 Registered: Aug-06
| Posted on Friday, August 25, 2006 - 10:37 pm: |
I'm having a problem with my speakers... ever since I had a Pioneer receiver deck installed in my car the front left tweeter sometimes goes out temporarily. I read somewhere that this happens when the speakers starts to go bad, but it never happened before I installed the cd deck. How can I fix this problem? Thanks. |
Gold Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 2644 Registered: Feb-05
| Posted on Friday, August 25, 2006 - 11:29 pm: |
more details on the speakers you are having problems with?? what HU?? how are the speakers being powered?? either a wireing problem or a protection device for the speakers. |
Bronze Member Username: Udalix
Manitoba
Post Number: 12 Registered: Aug-06
| Posted on Sunday, August 27, 2006 - 01:39 pm: |
If your using crossovers and an amp, just check to see if the wire is starting to come out of the crossover... Ive had this happen before, it would cut out once and awhile, just tightened it up and it was good, just a thought |
