Thread: Equlizers |
Bronze Member Username: Jeffkock
Post Number: 63 Registered: Aug-06
| Posted on Friday, August 25, 2006 - 02:57 am: |
I want to buy a Alpine IVA-D310 but they only have 2volt outputs and I want to get a equlizer with higher outputs which should i get. |
Relevant Product Info
Platinum Member Username: Glasswolf
Wisteria,
Lane
Post Number: 11590 Registered: Dec-03
| Posted on Friday, August 25, 2006 - 10:15 am: |
Audiocontrol. |
Bronze Member Username: Bobimpact
Danbury,
CT
US
Post Number: 62 Registered: May-06
| Posted on Thursday, August 31, 2006 - 09:16 pm: |
PXA-H701 is the direct connection piece for the 310. |
Danbury,
CT
US
Post Number: 63 Registered: May-06
| Posted on Thursday, August 31, 2006 - 09:17 pm: |
And has 4 volt outs, BTW. |
Silver Member Username: Johnfiac
Il
Post Number: 375 Registered: Mar-06
| Posted on Wednesday, September 06, 2006 - 11:36 pm: |
What is the best brand\recommended equalizers? Im looking for a 4V-8V output with 3sets of rca channel inputs, is it ok to run subs and components threw the same eq. or do i need 2 for that, would i set my HU to FLAT instead of my user settings for the eq. on it? |
Silver Member Username: Bobimpact
Danbury,
CT
US
Post Number: 120 Registered: May-06
| Posted on Thursday, September 07, 2006 - 12:11 am: |
Audiocontrol makes good stand along EQs. Yes it's fine. Yes you would use the EQ instead. |
