Home > Message Board > Car Audio > Multimedia Systems > Archive through February 06, 2007 > Alpine IVA-D310 , DVA-9965 9861 9860 ...
Author Thread: Alpine IVA-D310 , DVA-9965 9861 9860 DVE-5207 IVA-W200, IVA-D100 PKG-2000P All region Update
Username: 355evo
Australia
Noticed that a few people were chasing the Update to enable the IVA-D310 for multiregional dvds please see the list below of what is available. We are interested in purchasing any of the IVA system dead or alive
Thanks you can email me here at evo355@bigpond.com
It is a simple install just load the disc and a couple of magic buttons later and it loaded, please not that you can only use the disc once as it is a read once only disc, just to protect our IP etc. Plus if it is attempted to be copied it will not function as it will alter the information needed on the disc and will render you head unit useless, and they you will need to send it to us for the fix. SO you are warned, if you think that you can copy and sell our disc as it is not possible, or lend them out to everyone with the same system, as we will not be held liable for the stupid actions of some.
All disc are sent priority worldwide, cost is US$125.00
See photos of the install to confirm.
Models available as follows; each require a different disc.
IVA-W200
IVA-D310
IVA-D100
DVA-9860
DVA-9861
DVA-9965
DVE-5207
PKG-2000P
PKG-RSE2
Thanks
355EVO
Username: Pollo_volador
Espaņa, Pontevedra
Cambados
Post Number: 7
Por favor podias mandarme el cd a spaņa ??? soy espaņol y no hablo ingles
Username: Manley
i have a alpine iva-d310 h/u i lost power to it so i checked the fuse in the car and that was fine so what else could it be
Username: 355evo
Australia
it may be either the accessory wire or the illumination wire, as both need to be connected and powered for the HU to work.
How did you lose power to it??
Username: Manley
i was starting and stoping the engine three times and the radio lost power
Username: 355evo
Australia
sounds like a fuse. You may need to rest the unit itself... though you need to determine if you have power at the fuse on the HU coming into the fuse and then check to the HU on the HU side....
Will need a test light or volt meter
Username: Manley
i have a alpine iva-d310 and it keep tripping the fuse on my radio i never had this problom before this just starting happening
Username: 355evo
Australia
Post Number: 7
How does it trip the fuse??
Does it power up etc.
Sound like it may be a loose ribbon inside the unit, a short in your wiring harness, or a dry solder joint.
All are typical of Alpine on most of there units, you only have to look at how many people have a drama with the CDs not coming out of the CDA-9855 and all of the 98 series HUs.
Nice to see that they can trade off the name they had, and not the quality of crap they now produce.
Username: Manley
i had the radio playing for five days and then it tripped
Username: Doggett
how do you bypass the parking brake on the alpine iva-d100
Home > Message Board > Car Audio > Multimedia Systems > Archive through February 06, 2007 > Alpine IVA-D310 , DVA-9965 9861 9860 ... [ « Previous ] [ Next » ]
