Thread: Cascade Performance Speaker Kit?? |
Bronze Member Username: Alexochoa
Tucson,
Arizona
Post Number: 95 Registered: Jan-05
| Posted on Tuesday, August 22, 2006 - 10:11 am: |
Has anyone used these before? Are they any good? "Place the Powerpads behind your speakers to wipe out cone breakup and distortion. Deflex Pads will help tighten up your midbass and improve your soundstage." I'm going to install some CDT's (my first comp set!!) and i was wondering if i should pay the extra $35 for these kits. Thanks in Advance |
Silver Member Username: Rick_ross
Post Number: 409 Registered: May-06
| Posted on Wednesday, August 23, 2006 - 11:31 pm: |
i had the trunk kit and it was good i had edead to and i liked the cascade better |
Gold Member Username: Alteraudiousa
Concord
Post Number: 1167 Registered: Jan-06
| Posted on Wednesday, August 23, 2006 - 11:48 pm: |
the powerpad is to break up standing waves, IIRC. I haven't put it in my doors but its on my list as I hope it will eliminate any chance of standing waves or dull midbas in my doors. |
Tucson,
Arizona
Post Number: 97 Registered: Jan-05
| Posted on Thursday, August 24, 2006 - 10:07 am: |
well, i guess it's a good buy. Thanks again for your input and help! |
