Thread: Alpine Type X comp |
New member Username: Thed42
Post Number: 9 Registered: Jun-06
| Posted on Tuesday, August 22, 2006 - 09:01 am: |
Does anyone have opinions on the type X components? I like how they have a ring raidating tweeter. I think the 5.25's are rating at like 60 watts. Any like theese or have any problems? |
Silver Member Username: Adddisorder
West palm,
Florida
Post Number: 602 Registered: Jan-06
| Posted on Tuesday, August 22, 2006 - 02:23 pm: |
got to give them alot more power trust me 125-150 should be good |
Gold Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 2609 Registered: Feb-05
| Posted on Wednesday, August 23, 2006 - 01:23 am: |
i havent heard the newer versions, but they are suppose to be nice. 60 watts won't cut it though, go with what Mat suggested. |
Gold Member Username: Alteraudiousa
Concord
Post Number: 1165 Registered: Jan-06
| Posted on Wednesday, August 23, 2006 - 01:26 am: |
definitely need more power, IIRC they are off a Vifa driver which tend to do better with more power. I heard one last year so not sure if it was the up to date version or not but quite nice and really nice when you have two 6.5s in the doors and the tweeter. I still prefer CDT's silks though. |
Post Number: 10 Registered: Jun-06
| Posted on Wednesday, August 23, 2006 - 08:59 am: |
Thanks for the input guys, Are those CDT silk even more mild (less harsh) than that vifa ring raiditing tweet? |
West palm,
Florida
Post Number: 606 Registered: Jan-06
| Posted on Wednesday, August 23, 2006 - 05:12 pm: |
i dont think youll have to worry about the tweet being to harsh iv got the R set and they sound great, but if its to harsh for you maybe drop the higher freq. on your HU |
Silver Member Username: Justblaze
St.Louis,
MO
Post Number: 120 Registered: Jun-06
| Posted on Saturday, August 26, 2006 - 12:32 pm: |
even if it is too harsh, if the crossover on the x is anything like on my type-R components, you can adjust the tweeter level. i think i have mine at either -1.5 or -3.0 dB |
