Thread: Wiring diagram for Pioneer KEH-2650 |
New member Username: Nilomp
Philippines
Post Number: 1 Registered: Aug-06
| Posted on Tuesday, August 22, 2006 - 12:34 am: |
Hi There! Does anyone knows the wiring diagram (Olor Coding) for Pioneer KEH-2650 car stereo? hope u can help me, thanks alot |
Relevant Product Info
Gold Member Username: Illuminator
Post Number: 4327 Registered: Apr-05
| Posted on Tuesday, August 22, 2006 - 06:31 pm: |
It should be the same as any other aftermarket receiver:
Blue wire w/white stripe is remote wire for your amps(not included in pic). Source: www.bcae1.com |
Philippines
Post Number: 2 Registered: Aug-06
| Posted on Wednesday, August 23, 2006 - 04:21 am: |
thanks for the reply, but my car stereo have the following wire color 1. Black 2. Orange 3. Black with gray stripe 4. White with red stripe 5. Black with green stripe 6. Green with red stripe 7. White with black stripe 8. Gray 9. Green with black Stripe 10. Green 11. red 12. Blue for the Items 1, 2, 11, 12 no problem for items 3 to 10 is for the speaker out which i cannot distinguished terminal the for front left and right speaker including their polarity, also for rear left and right speaker. can you help me? thanks alot |
Post Number: 4358 Registered: Apr-05
| Posted on Wednesday, August 23, 2006 - 09:45 am: |
Everything looks good, you have to remember the white on my diagram represents both negative and positive which correspond to the polarity of a speaker. Therefore solid white is positive, and the white with a black stripe is negative. These are your deviating wires from the diagram: 4. White with red stripe 5. Black with green stripe 6. Green with red stripe 7. White with black stripe 4 and 7 seem like the left front 5 and 6 seem like the right rear 9 and 10 are left rear 3 and 8 are right front If those don't work, you'll have to play around with the wires and see what you can get to work. I can't guarantee what I have said is correct and I'm not liable for any damage that may occur by following the above said advice. If at all possible, a picture would be VERY nice.  |
