Thread: 1992 stock radio help |
New member Username: Mwj450
Post Number: 3 Registered: Aug-06
| Posted on Saturday, August 19, 2006 - 03:41 pm: |
im having trouble removing my stock radio from my 1992 ford thunderbird, if you have any ideas or u know how to take it out please let me know |
Gold Member Username: Illuminator
Post Number: 4158 Registered: Apr-05
| Posted on Saturday, August 19, 2006 - 04:21 pm: |
Ford head units will have two holes on either side that you can stick a coat hanger in, bend out, and slide the head unit out (a trick is to also use two flathead screwdrivers that slip between the side of the unit). |
Post Number: 4159 Registered: Apr-05
| Posted on Saturday, August 19, 2006 - 04:23 pm: |
Also, the keys to remove it are ~$15 from Walmart, a Ford dealership, or ebay. |
Silver Member Username: Kaerfpl
Spencerport,
NY
Post Number: 383 Registered: Jun-06
| Posted on Saturday, August 26, 2006 - 11:16 pm: |
I got mine from Advanced Auto Parts for $5... |
New member Username: Roger822
Post Number: 1 Registered: Aug-06
| Posted on Wednesday, August 30, 2006 - 12:04 pm: |
need wiring diagram for 1992 Ford Explorer stereo system. Mine was stolen, all wires were cut, am replacing with Audiovox Rampage ACD-83, can anyone help? |
Post Number: 4640 Registered: Apr-05
| Posted on Wednesday, August 30, 2006 - 03:54 pm: |
I take it you are getting rid of the car soon, Roger? That head unit won't last more than six months. Most die within two months-specifically the CD mech, and at that point it isn't repairable because low-end brands like that don't sell parts, you're expected to throw it away. |
Silver Member Username: Adddisorder
West palm,
Florida
Post Number: 700 Registered: Jan-06
| Posted on Wednesday, August 30, 2006 - 04:19 pm: |
i got mine out with a screw driver and some plyers, not exatly profesional but i was pissed at it ;) at one point it caught on fire! dont think thats good but hey i got it out |
