Thread: What are the best subwoofers for under $100? |
New member Username: Silvermopar
Nebraska
Post Number: 2 Registered: Aug-06
| Posted on Friday, August 18, 2006 - 12:23 pm: |
What are the best subwoofers for my suv that are under $100? i already have a 300watt power output pyramid amp/equalizer to run them on. |
Nebraska
Post Number: 3 Registered: Aug-06
| Posted on Friday, August 18, 2006 - 12:37 pm: |
im sorry for double posting im kinda new at this and was in wrong spot to start when i first posted |
Silver Member Username: Rick_ross
Post Number: 379 Registered: May-06
| Posted on Friday, August 18, 2006 - 01:07 pm: |
you can get cvr's for under 100 on ebay but that amp is a piece of sh1t and isnt gonna push anything |
Nebraska
Post Number: 5 Registered: Aug-06
| Posted on Friday, August 18, 2006 - 11:18 pm: |
since everyone thinks my amp sucks what amp and woofers should i get i will have a little more $$ in a few days which i would consider spending(if it would make a noticable diffrence) but im still on a tight budget :-{ |
Gold Member Username: Illuminator
Post Number: 4138 Registered: Apr-05
| Posted on Friday, August 18, 2006 - 11:37 pm: |
Get a PPI amp from ebay, they're cheap and awesome. http://cgi.ebay.com/Precision-Power-PPI-PC2100-Amp-Great-Condition-L-K_W0QQitemZ 120020654889QQihZ002QQcategoryZ18796QQssPageNameZWDVWQQrdZ1QQcmdZViewItem |
Bronze Member Username: Grebnereon
Post Number: 96 Registered: Mar-06
| Posted on Saturday, August 19, 2006 - 12:14 am: |
for subs, i would suggest memphis power reference subs, their specs dont look very good, actually just their rms rating which is 200 watts, but they are awesome, they can handle 400 watts no problem and if you buy them from a dealer, if anything ever happens to them, as long as you got ur repciept, memphis will fix or replace ur subs for free |
Post Number: 97 Registered: Mar-06
| Posted on Saturday, August 19, 2006 - 12:20 am: |
for subs, i would suggest memphis power reference subs, their specs dont look very good, actually just their rms rating which is 250 watts, but they are awesome, they can handle 400 watts no problem and if you buy them from a dealer, if anything ever happens to them, as long as you got ur repciept, memphis will fix or replace ur subs for free |
Nebraska
Post Number: 7 Registered: Aug-06
| Posted on Saturday, August 19, 2006 - 09:34 am: |
thanks for the help guys |
Silver Member Username: Delsole
Post Number: 417 Registered: Feb-05
| Posted on Sunday, August 20, 2006 - 06:27 pm: |
check out Ascedent audio www.ascendantaudio.com great sound quality |
Silver Member Username: Kklagge
Post Number: 267 Registered: Dec-04
| Posted on Thursday, August 24, 2006 - 06:21 am: |
You can also look at some Diamond Audio D3's |
Silver Member Username: Cavsmaxima
New York
United States
Post Number: 122 Registered: Aug-06
| Posted on Monday, September 04, 2006 - 07:11 pm: |
Your best bet is to save up some money for a little. It's Better to wait a few more months and get something good then get something and not be satisfied. You know what i mean? |
Gold Member Username: Jakeyplaysbass
St. Louis,
MO
Post Number: 1455 Registered: Jul-05
| Posted on Monday, September 04, 2006 - 09:11 pm: |
kicker compVR. |
Bronze Member Username: Auroradrvr
Ft. Lauderdale,
Florida
Post Number: 17 Registered: Jul-06
| Posted on Sunday, September 10, 2006 - 02:12 am: |
x2 |
Silver Member Username: Bernymac
Rialto,
CA
United States
Post Number: 178 Registered: Sep-04
| Posted on Sunday, September 10, 2006 - 02:47 am: |
I agree with Chris, If you wait awhile and just settle with what you have right now, you'll end up satisfied in the long run. |
Silver Member Username: Spidercoder
Palm Harbor,
Florida
Post Number: 108 Registered: Aug-06
| Posted on Friday, September 15, 2006 - 03:44 pm: |
I would go with diamond d3 if I were you. |
Silver Member Username: Jkidder
Spring hill,
Florida
Usa
Post Number: 234 Registered: Nov-05
| Posted on Sunday, September 17, 2006 - 03:43 pm: |
if u really want a sub now id get the assassin from ascendant audio. great sound quality but like they said i would save up more money. |
Silver Member Username: Logan__tille
Hamilton,
Indiana
United states
Post Number: 977 Registered: Feb-06
| Posted on Sunday, September 17, 2006 - 08:37 pm: |
get some assassins |
