Thread: Tweeters |
Gold Member Username: Redliner
Wilmington,
Ma
Post Number: 2238 Registered: Jun-05
| Posted on Thursday, August 17, 2006 - 10:20 pm: |
how do u put tweeters in if theer is no spot for them in the door sorry ive never put them in before thanks guys and im talking running wires and everything |
Silver Member Username: Rick_ross
Post Number: 352 Registered: May-06
| Posted on Thursday, August 17, 2006 - 10:36 pm: |
put the crossover inside the door and run the wire from the tweeter to that and cut a hole for the tweeter |
Gold Member Username: Mixneffect
Orangevale,
Ca.
Post Number: 1066 Registered: Apr-05
| Posted on Tuesday, August 22, 2006 - 03:17 pm: |
Just wondering; WHAT EXACTLY HAVE YOU BEEN DOING ALL THIS TIME, SINCE YOU ARE A "gold member?" |
Bronze Member Username: Alexochoa
Tucson,
Arizona
Post Number: 96 Registered: Jan-05
| Posted on Tuesday, August 22, 2006 - 10:35 pm: |
lol!! Mixneffect... |
Gold Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 2607 Registered: Feb-05
| Posted on Wednesday, August 23, 2006 - 01:13 am: |
member status really doesn't mean you know anything more then the next person. |
Orangevale,
Ca.
Post Number: 1070 Registered: Apr-05
| Posted on Wednesday, August 23, 2006 - 03:56 pm: |
I am not trying to be a jerk, but the above mentioned inquiry seems like a logical question and is almost a non issue. Cmon really! In the amount of time it takes to post 1000 times, one would only assume that you should also read other posts and learn. There have been numerous posts, even with pictures with systems that were installed in modified places. So thats why I asked. I just assumed that someone that has been arround here for a while should already have an idea wher to put a tweeter if a factory cutout does not exist. Also, I asked it because it may be that charlie has probably been posting in other sections such as games and computers, who knows, right? No Pun Intended Charlie peace |
Bronze Member Username: Bobimpact
Danbury,
CT
US
Post Number: 55 Registered: May-06
| Posted on Thursday, August 31, 2006 - 05:20 pm: |
If your location is not set in stone then hook everything up, move your tweeter around and place it where it sounds the best. Also, if you can avoid it, do not put the crossover inside of the door panel. No matter where you put it you run a high risk of the crossover rusting, which is no good for your shiny new speakers.  |
Wilmington,
Ma
Post Number: 2270 Registered: Jun-05
| Posted on Friday, September 01, 2006 - 11:10 pm: |
it was just a question on how to run the wires and exactly what wires i need to run i know where they go and everything but how often do we actually talk abotu actual wiring on this website honestly but ya atleast im asking a question better then just being a a## abotu soemthing trying to make someone look stupid which by the way i will never take credit for something i dont know and this is one of them and also i dont know much about box building so get over it im a gold member yes and do i deserve to be with what i know i would say yes there are just a couple topics i dont know about i mean do you know everything in car audio no nobody does thats waht these forums are for to ask questions just liek i just did so after all that stfu |
Silver Member Username: Dkchillin
Vermont
Post Number: 269 Registered: Mar-05
| Posted on Friday, September 01, 2006 - 11:32 pm: |
You'll need to run your positive and negative speaker wires to your crossover and then from the crossover + and - to the tweeter and another set of + and - to the woofer, it's that simple. As has been said, if you don't have stock tweets then play around with the location to figure out where you like them. You can put you crossovers where you want and plenty of people put them in the door. It's not the best place but it's an option. I've seen crossovers all over the place, glove box, behind the dash, under seats and I actually have mine in the trunk as part of my stock amp bypass. Once you get all the components and take a look at what you have to work with it's fairly self explanitory. |
Wilmington,
Ma
Post Number: 2275 Registered: Jun-05
| Posted on Friday, September 01, 2006 - 11:34 pm: |
ya ive never actually seen comps up close and uninstalled thanks for the explanation though |
Gold Member Username: Dustin3
Tigard,
OR
U.S.
Post Number: 3297 Registered: Oct-05
| Posted on Saturday, September 02, 2006 - 05:07 pm: |
lol. wow, mixineffect, who the f@ck cares just because you dont know EVERYTHING about car audio doesnt mean that ur an idiot. |
Gold Member Username: Alteraudiousa
Concord
Post Number: 1198 Registered: Jan-06
| Posted on Sunday, September 03, 2006 - 01:03 pm: |
actually, I like to test the tweeters in a bunch of different spots first and try them in and out of phase to see if it makes a difference. I would suggest getting some velcro and mounting the tweeters in different positions in the car to see where the best sound is and then also try them out of phase. Wiring out of phase is you switch the polarity. I kinda am suprised you asked this question too but o well atleast its a better question that "which one is better" |
Wilmington,
Ma
Post Number: 2345 Registered: Jun-05
| Posted on Friday, September 08, 2006 - 10:06 am: |
ive just never had any hands on experience with tweets ive only done reg speakers subs and amps okay and the occasional hu |
Gold Member Username: Invain
Michigan
United States
Post Number: 4125 Registered: Aug-04
| Posted on Friday, September 08, 2006 - 12:30 pm: |
If you've never worked with components, I'd have somebody that has install them. Sound imaging is everything. |
Wilmington,
Ma
Post Number: 2356 Registered: Jun-05
| Posted on Friday, September 08, 2006 - 02:14 pm: |
ill be fine i have a couple good guys that know what there doing |
New member Username: Tyler_from_harrisburg
Post Number: 1 Registered: Sep-06
| Posted on Wednesday, September 13, 2006 - 08:22 pm: |
hey whats up im lookin for some help on installing tweeters in a 2000 ford explorer i already have replaced my factory speakers and need to know how to install tweeters they have a built in crossover.. thanks fot the help |
Post Number: 2 Registered: Sep-06
| Posted on Wednesday, September 13, 2006 - 08:23 pm: |
hey whats up im lookin for some help on installing tweeters in a 2000 ford explorer i already have replaced my factory speakers and need to know how to install tweeters they have a built in crossover.. so yea if you could just tell me everything that would be great .. allright thanks |
Concord
Post Number: 1230 Registered: Jan-06
| Posted on Wednesday, September 13, 2006 - 09:58 pm: |
it if has its own crossover than you wire it into the speaker wires. If the crossover has outputs for a woofer than you wire the speaker wire into the input and than seperate wires go out from the woofer and tweeter outputs to their respective drivers. |
Silver Member Username: Gangstafert
Jacksonville,
Florida
Post Number: 310 Registered: May-06
| Posted on Wednesday, September 13, 2006 - 10:26 pm: |
Does any one know where to get some kick panels for a 94 cutlass. I checked Qlogic and they didnt have my car so i was wandering if there was other places. Thanks |
