Home > Message Board > Car Audio > Disc Changers > Archive through September 05, 2006 > Aftermarket stereo/CD changer for 200...
Author Thread: Aftermarket stereo/CD changer for 2004 Lexus RX 330
Username: Third_eye
I'm looking to replace the factory car stereo on my 2004 Lexus RX 330. I called Krommer Radio in Toronto and they said they can't do it. Does anyone know if (a) it can be done; and (b) there's any other shop in Toronto and GTA that can do it?
Thanks.
Third_Eye
(in Toronto)
Username: Dwight11
Post Number: 16
a- yes b- yes
Username: Jmp21
United States
i believe there is a lexus dealership called scarborough lexus in toronto, they could possibly help you out im not sure though just an idea
Username: Third_eye
Dwight,
So which shops in GTA do you know that can install it? Can you name a few?
jmp,
yeah, I know the dealerships here, there are a limited no. of them in GTA. Thanks for the feedback.
3-I
Home > Message Board > Car Audio > Disc Changers > Archive through September 05, 2006 > Aftermarket stereo/CD changer for 200... [ « Previous ] [ Next » ]
