Thread: Archive through July 20, 2006 |
New member Username: Tomtit
Post Number: 1 Registered: Jun-06
| Posted on Thursday, June 29, 2006 - 07:56 am: |
i've just bought a 1993 ford escort and need to fit a stereo. however the colour coding of the stereo wires in the vehicle is totally different to the codes given on this page and everywhere else i've found online. i've managed to figure out the speaker wires but i can't work out the others. they are: red, brown, yellow, blue/yellow, brown/white and fat brown. if anyone can help i'd be grateful |
Post Number: 2 Registered: Jun-06
| Posted on Thursday, June 29, 2006 - 07:59 am: |
Bronze Member Username: Makmillion
United States
Post Number: 64 Registered: Apr-06
| Posted on Thursday, June 29, 2006 - 11:38 am: |
2002 Ford Focus stereo wiring..???? reply in the next few hours would be hugely appreciated as I have to do the install at 3:30(it's 10:30) |
United States
Post Number: 65 Registered: Apr-06
Gold Member Username: Tjmutlow
Post Number: 2470 Registered: Sep-05
| Posted on Thursday, June 29, 2006 - 12:33 pm: |
DIRECTWIRE WIRING INFORMATION - FORD / FOCUS / 2002 / Audio Radio 12v orange/black (thick) + radio Radio Ground blk/yel & blk/grn - radio Radio Ignition yellow/green + radio Radio Illumination orange/black (thin) + radio Factory Amp Turn-on Power Antenna LF Speaker +/- wht/blk - gry/blk radio RF Speaker +/- wht/red - gry/red radio LR Speaker +/- wht/pur - gry/wht radio RR Speaker +/- white - gray radio Interface Module: Category: Immobilizer Bypass Required: Yes Type: SecuriLock Part #: 555SW Alternate Part1 #: 556UW Alternate Part2 #: 555U Notes: This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter. Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information. |
New member Username: Crayola0
Post Number: 5 Registered: Jun-06
| Posted on Thursday, June 29, 2006 - 02:18 pm: |
Thanks Ty i did that and now it works great and sounds great too. Thanks . |
Bronze Member Username: Kbenz47
Rochester,
New York
United States
Post Number: 44 Registered: Jan-06
| Posted on Thursday, June 29, 2006 - 03:17 pm: |
can i get the alarm and cruise info? |
New member Username: Buddha
Post Number: 4 Registered: Jun-06
| Posted on Thursday, June 29, 2006 - 03:29 pm: |
2006 Ford F150 xlt speaker wire colors??? |
Post Number: 2476 Registered: Sep-05
| Posted on Thursday, June 29, 2006 - 06:31 pm: |
1999 Honda Civic Security Information Constant 12V+ White Ignition Switch Harness Starter Black/White Ignition Switch Harness or White 6 Pin Plug behind Fuse Panel Ignition Black/Yellow Ignition Switch Harness Ignition 2 Yellow Ignition Switch Harness Accessory White/Black Ignition Switch Harness Tach Blue Coil Neutral Safety Wire Black/Blue (-) Brake Switch Green/White Brake Switch Trunk Pin Blue/Black (-) Driver's Kick or Alarm Connector right of Column Parking Lights Red/Black (+) Keyless Entry Module or above Fuse Panel Head Lamp Red/White left. Red/Blue right at Steering Column Door Trigger Light Green/Red (-) Alarm Connector right of Steering Connector is Green Door Lock Green/White (-) Above Fuse Panel or Keyless Module or behind Radio Green Connector Door Unlock Green/Orange (-) Driver's Lock White/Red Driver's Kick Panel Driver's Unlock Blue/Red Driver's Kick Panel Passenger Unlock Yellow/Red Keyless Entry Module Horn Wire Gray (-) Steering Column or Green Connector behind Radio Windows Up LF=Red/Blue, RF=Blue/Yellow, LR=Green/Yellow, RR=Yellow Windows Down LF=Red/Yellow, RF=Blue/Orange, LR=Green, RR=Yellow/Green Cruise Information Stereo Information 1999 Honda Civic Cruise Information Constant 12V+ White Ignition Switch Harness or Use Hot Side of Brake Switched 12V+ Black/Yellow Ignition Switch Harness Ground Use Chassis Near Cruise Control Module Hot Side of Brake n/a Brake Switch Cold Side of Brake Green/White Brake Switch Tach Blue Coil VSS Lead Blue/White Passenger's Firewall 3 Pin Connector top Transaxle Pulses Per Mile 4000 PPM Notes: Vehicles with Manual Transmission require Clutch Switch. Some vehicles may require a speed signal generator and/or other parts/adapters not listed above. Rostraฎ Cruise module switch settings may differ if you use a speed signal generator or magnets and a pick up coil. Alarm Information Stereo Information |
New member Username: Hferdjal
| Posted on Thursday, June 29, 2006 - 08:18 pm: |
May I get the radio wiring diagram for a Chevrolet Malibu 1998? You posted the diagram for a 99 earlier in this thread, but the colors are significantly different for the 98 version. Really appreciate it man. |
Post Number: 2479 Registered: Sep-05
| Posted on Thursday, June 29, 2006 - 09:11 pm: |
1998 Chevrolet Malibu Stereo Information Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Trigger Pink Antenna Right Rear Front Speakers 4" x 6" Doors Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 6" x 9" Rear Deck Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue |
New member Username: Harvestland
| Posted on Thursday, June 29, 2006 - 10:19 pm: |
how about for a 1998 ford contour? |
New member Username: Mitsibishi23
| Posted on Friday, June 30, 2006 - 12:00 am: |
I NEED WIRING INFORMATION FOR 2000 MITSIBISHI MIRAGE DE SEDAN DESPERATLEY!!!!!!!!!!!!!!!!!!!! HELP!!!!!!!!!! |
Post Number: 3 Registered: Jun-06
| Posted on Friday, June 30, 2006 - 12:01 am: |
I NEED STEREO WIRING INFORMATION FOR 2000 MITSIBISHI MIRAGE DE SEDAN DESPERATLEY!!!!!!!!!!!!!!!!!!!! HELP!!!!!!!!!! |
New member Username: Nickwood
| Posted on Friday, June 30, 2006 - 12:44 am: |
i NEED TO KNOW HOW TO HOOK UP MY KENWOOD DECK INTO MY CAR. IT IS A 1995 SATURN AND I CANT FIGURE OUT WHICH WIRES ARE SUPPOSE TO BE HOOKED UP TO WHERE. THERE ARE ALL KINDS OF DIFFERENT COLORS. |
New member Username: Djokfr60
| Posted on Friday, June 30, 2006 - 04:33 am: |
Hi, Can someone help me on the colors for a Ford Focus TDCI 115 year 05? Thx a lot... Djok |
New member Username: Mcarrierd
| Posted on Friday, June 30, 2006 - 07:26 am: |
I need the stereo wiring for a 1993 Mustang. I have searched everywhere for it! Thanks in advance! |
New member Username: S_king
| Posted on Friday, June 30, 2006 - 08:36 am: |
i need help with the color codes for an '02 Dodge Stratus. thanks in advance |
New member Username: Mitsigirl
| Posted on Friday, June 30, 2006 - 09:24 am: |
hey guys, i need a wiring diagram for a 93 mitsi Colt to get my head unit connected. can anyony help? |
Post Number: 2481 Registered: Sep-05
| Posted on Friday, June 30, 2006 - 12:19 pm: |
1998 Ford Contour Stereo Information Constant 12V+ Orange/Black Switched 12V+ Blue/Black Ground Black/Green Illumination White/Green Dimmer n/a Antenna Right Rear Front Speakers 5" x 7" Doors Left Front (+) White/Black Left Front (-) Brown/Yellow Right Front (+) White/Red Right Front (-) Brown/Yellow Rear Speakers 5" x 7" Rear Deck Left Rear (+) White/Purple Left Rear (-) Brown/White Right Rear (+) White/Purple Right Rear (-) Brown/White Alarm Information Cruise Information |
New member Username: Paster120
| Posted on Friday, June 30, 2006 - 12:37 pm: |
Hi i need the stereo wiring for a 1997 na supra. I have searched everywhere for it! Thanks pad. |
Bronze Member Username: Ciera_cutless
Post Number: 41 Registered: Apr-06
| Posted on Saturday, July 01, 2006 - 03:38 pm: |
does anyone have new the color code for the stereo in a 96 acura integra? |
Post Number: 42 Registered: Apr-06
does anyone have the color code for the stereo in a 96 acura integra? |
New member Username: Clayman2006
Post Number: 1 Registered: Jul-06
| Posted on Sunday, July 02, 2006 - 02:58 pm: |
I have a 95 Dodge Dakota and I just bought a panasonic CQ-C9701U 70x4 cd player but it didn't come with an owners manual. My question is does anyone know what wire is what on the panasonic wiring harness? |
Post Number: 2495 Registered: Sep-05
| Posted on Sunday, July 02, 2006 - 03:28 pm: |
they should be makerd is small lettering, but if you have the aftermarket harness for that car(best way to run a radio) the wires will match up. |
Post Number: 2496 Registered: Sep-05
| Posted on Sunday, July 02, 2006 - 03:30 pm: |
1996 Acura Integra Stereo Information Constant 12V+ Blue/White Switched 12V+ Yellow/Red Ground Black Illumination Red/Black Dimmer n/a Antenna Trigger n/a Antenna Left Rear Front Speakers 5 1/4" Doors Left Front (+) Blue/Green Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black Rear Speakers 6" x 9" Rear Deck Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White Alarm Information Cruise Information 1996 Acura Integra Stereo Information Constant 12V+ Blue/White Switched 12V+ Yellow/Red Ground Black Illumination Red/Black Dimmer n/a Antenna Trigger n/a Antenna Left Rear Front Speakers 5 1/4" Doors Left Front (+) Blue/Green Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black Rear Speakers 6 1/2" Side Panels Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White Alarm Information Cruise Information |
Post Number: 2497 Registered: Sep-05
| Posted on Sunday, July 02, 2006 - 03:31 pm: |
1995-97 Toyota Supra Stereo Information Constant 12V+ Blue/Yellow Switched 12V+ Gray Ground Brown Illumination Green Dimmer n/a Antenna Trigger Black/Red Antenna Right Rear Front Speakers 4" Doors Left Front (+) Pink Left Front (-) Purple Right Front (+) Light Green Right Front (-) Blue Rear Speakers 5" Side Panels Left Rear (+) Black Left Rear (-) Yellow Right Rear (+) Red Right Rear (-) White |
New member Username: Simko
| Posted on Sunday, July 02, 2006 - 03:43 pm: |
I have a 2001 sunfire and when I test the wires, no ignition power lights up. could I get the wiring colour scheme plz? |
Post Number: 2502 Registered: Sep-05
| Posted on Sunday, July 02, 2006 - 03:48 pm: |
could not find 01, maybe 00 will work. 2000 Pontiac Sunfire Stereo Information Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Trigger Pink Antenna Right Front Front Speakers 4" x 6" Doors Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 6" x 9" Rear Deck Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue Alarm Information Cruise Information |
Post Number: 2505 Registered: Sep-05
| Posted on Sunday, July 02, 2006 - 03:54 pm: |
alos on sunfire, been awhile since i did one, but it had a relocation harness and i think there was no power ar the harness benind the radio(switched), you can run them direct to fuse block., but double check all fuses first(both sides of the fuse) |
Post Number: 2 Registered: Jul-06
| Posted on Sunday, July 02, 2006 - 06:39 pm: |
Thanks Ty, that second posting was what really helped me. I couldn't figure out where to get my switched power from until you suggested running direct into the fuse block, which instantaneously sparked my memory. Much appreciated for the help, and thanks for you time! P.S. 2000 -2001 sunfires do have the same colour scheme for wiring, so does everything else after 1997 up to the 2004 ( with pontiac sunfires) |
New member Username: Trojan_horse
Fayette,
MO
United States
| Posted on Sunday, July 02, 2006 - 08:30 pm: |
Can I please get a radio wiring diagram for a 1989 Mustang GT Convertible? Thanks. |
New member Username: Klyed
| Posted on Sunday, July 02, 2006 - 08:32 pm: |
I need a 96' ford explorers color codes for new head unit |
Post Number: 2518 Registered: Sep-05
| Posted on Sunday, July 02, 2006 - 10:46 pm: |
1988-89 Ford Mustang Stereo Information Constant 12V+ Green/Yellow Switched 12V+ Yellow/Black Ground Chassis Illumination Blue/Red Dimmer n/a Antenna Trigger Orange/Blue Antenna Right Front Front Speakers 5 1/4" Doors Left Front (+) Orange/Green Left Front (-) Light Blue/White Right Front (+) White/Green Right Front (-) Green/Orange Rear Speakers 5" x 7" Side Panels Left Rear (+) Pink/Green Left Rear (-) Pink/Blue Right Rear (+) Pink/Blue Right Rear (-) Green/Orange Alarm Information Cruise Information |
Post Number: 2519 Registered: Sep-05
| Posted on Sunday, July 02, 2006 - 10:48 pm: |
1995-96 Ford Explorer Stereo Information Constant 12V+ Green/Purple Switched 12V+ Yellow/Black Ground Black/Light Green Illumination Light Blue/Red Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) White/Light Green Right Front (-) Dark Green/Orange Rear Speakers 5" x 7" Rear Doors Left Rear (+) Gray/Light Blue Left Rear (-) Tan/Yellow Right Rear (+) Orange/Red Right Rear (-) Brown/Pink Alarm Information Cruise Information |
Fayette,
MO
United States
| Posted on Sunday, July 02, 2006 - 11:15 pm: |
Thanks a million Ty! That'll be a big help. BG |
| Posted on Monday, July 03, 2006 - 01:42 am: |
can i get stereo wiring information for a 2000 Mitsibishi Mirage ? ? ? plz? |
New member Username: James_007
| Posted on Monday, July 03, 2006 - 03:49 am: |
hey ty, i was wondering if u got a 1992 toyota paseo colour code and is there a diffrence bewteen a 12v memory wire and a 12v igniton wire?? thanks |
New member Username: M8ball
Aurora,
IL
| Posted on Monday, July 03, 2006 - 05:45 am: |
Need wiring diagram for 95 ford taurus. |
Post Number: 2521 Registered: Sep-05
| Posted on Monday, July 03, 2006 - 07:22 pm: |
1992-93 Toyota Paseo Stereo Information Constant 12V+ Blue/Yellow Switched 12V+ Gray Ground Brown Illumination Green Dimmer n/a Antenna Driver's Pillar Front Speakers 4" Doors Left Front (+) Pink Left Front (-) Purple Right Front (+) Light Green Right Front (-) Blue Rear Speakers 6 1/2" Rear Deck Left Rear (+) Black Left Rear (-) Yellow Right Rear (+) Red Right Rear (-) White one wire is constant power and the other is switched |
Post Number: 2522 Registered: Sep-05
| Posted on Monday, July 03, 2006 - 07:23 pm: |
1995 Ford Taurus Stereo Information Constant 12V+ Light Green/Yellow Switched 12V+ Yellow/Black Ground Black Illumination Light Blue/Red Dimmer n/a Antenna Trigger Orange/Light Blue Antenna Left Rear Front Speakers 6 1/2" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) White/Light Green Right Front (-) Dark Green/Orange Rear Speakers 5" x 7" Rear Deck Left Rear (+) Pink/Light Green Left Rear (-) Dark Blue/Orange Right Rear (+) Pink/Light Blue Right Rear (-) Tan/White Alarm Information Cruise Information |
| Posted on Monday, July 03, 2006 - 09:29 pm: |
hey i think i need to wire the whole radio back up like power and all that does any1 have lyk colour map for the whole front end of a 1992 toyota paseo. thanks |
New member Username: Stifler92274
| Posted on Tuesday, July 04, 2006 - 02:53 pm: |
anyone have it for a 1992 jetta |
Bronze Member Username: Xplorer98
Post Number: 12 Registered: Jun-06
| Posted on Tuesday, July 04, 2006 - 04:47 pm: |
I have a power antenna on a 98 ford explorer and it doesnt move when I turn the radio on. I also have a new deck does anybody know what wire I should jump the power antenna to to make it go up when the radio is on? |
Post Number: 2534 Registered: Sep-05
| Posted on Tuesday, July 04, 2006 - 05:12 pm: |
the radio has a power antenna lead on it. make sure you have it hooked up.not the remote turn on wire. |
Post Number: 2535 Registered: Sep-05
| Posted on Tuesday, July 04, 2006 - 05:13 pm: |
1985-92 Volkswagen Jetta Stereo Information Constant 12V+ Red Switched 12V+ n/a Ground Brown Illumination Gray/Blue Dimmer n/a Antenna Trigger White Antenna Left Front Front Speakers 3 1/2" Dash Left Front (+) Blue Left Front (-) Brown/Blue Right Front (+) Red Right Front (-) Brown/White Rear Speakers 6 1/2" Rear Deck Left Rear (+) Blue/Green Left Rear (-) Brown/Red Right Rear (+) Red/Green Right Rear (-) Brown/Black Alarm Information Cruise Information |
New member Username: Red_seal
Post Number: 6 Registered: Jul-06
| Posted on Tuesday, July 04, 2006 - 06:45 pm: |
Ty mutlow would you happen to have the wiring info on a 2002 F-150 Supercab? I searched through all the vechicles you have already posted and I didn't notice it anywhere. Thank you! |
| Posted on Tuesday, July 04, 2006 - 07:01 pm: |
Need wiring diagram for 2000 Mitsibishi Mirage |
New member Username: Jpmolt
| Posted on Wednesday, July 05, 2006 - 02:38 am: |
I have an 05 ford taurus. I'm going to install a cd player with the installation kit. It includes air conditioner switches. However, my car has an air bag light by the ac switches and the installation kit doesn't. Will that cause a problem? If so, what do I do to fix it. Anyone's help is greatly appreciated, thanks. |
Post Number: 3 Registered: Jul-06
| Posted on Wednesday, July 05, 2006 - 08:34 pm: |
Hey i have the radio connect right but i havent got any power it worked once but then when i turned it off i went to turn it back on but now it wont turn back on i have a toyota paseo 1992 and i have cheaked the radio fuse any one got any ideas for me??? |
New member Username: Paulperreault06
Biddeford,
Maine
| Posted on Thursday, July 06, 2006 - 07:58 pm: |
I need the wiring diagram for a factory radio for my 1997 chevrolet cavalier... Can anyone help me out? |
Post Number: 2566 Registered: Sep-05
| Posted on Thursday, July 06, 2006 - 08:07 pm: |
Stereo Information Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Trigger Pink Antenna Right Front Front Speakers 4" x 6" Doors Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 6" x 9" Rear Deck Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue |
New member Username: Nokturnel23
| Posted on Thursday, July 06, 2006 - 10:22 pm: |
I need help installing my CD player in my 1995 honda civic it has no harness it got cut out when bought... here are the cars wire colors... red with yello line brown white. gray white blue yellow black I know this one is ground... yellow with red white with blue. red with black. gray with black blue brown with black red with green... Now my CD wire harness colors are... Red some what pinkish... orange blue with white green green with black gray gray with black yellow white white with black purple purple with black if some one can tell me which car wire gose to what CD harness color to make it work that would be great I have been waiting way to long and driving with out music sucks the big one.. email me with any help.. thanks ahead of time. nokturnel23@verizon.net |
| Posted on Thursday, July 06, 2006 - 10:31 pm: |
also I don't know if I shorted any wires cause they were not coverd at all. All of the fuse's are fine and the CD player fuse I dont know what would happen if it shorted so TY the man let me know and the above is the most inportant thing right now.. thanks buddy. |
Silver Member Username: Kaerfpl
Spencerport,
NY
Post Number: 118 Registered: Jun-06
| Posted on Friday, July 07, 2006 - 12:07 am: |
Hi, I need wiring info on a 1997 Ford Probe. I took out the factory amp thats inside it and I also need to know what wires are what that come out of it. |
New member Username: Mitchman
Appleton,
Wi
Usa
| Posted on Friday, July 07, 2006 - 01:19 am: |
I need stereo color codes for a 1993 ford taurus gl |
Post Number: 2572 Registered: Sep-05
| Posted on Friday, July 07, 2006 - 05:03 am: |
Matt H, here is the wiring diagram for that car, alos use a test light an make sure you have power on both acces and constant power. the wires on the radio s/b marked. just match up/ 1995 Honda Civic Stereo Information Constant 12V+ Blue/White Switched 12V+ Yellow/Red Ground Black Illumination Red/Black Dimmer n/a Antenna Driver's Pillar Front Speakers 6 1/2" Doors Left Front (+) Blue/Green Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black Rear Speakers 5 1/4" Rear Deck Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White Alarm Information Cruise Information |
Post Number: 2573 Registered: Sep-05
| Posted on Friday, July 07, 2006 - 05:05 am: |
1992-93 Ford Taurus Stereo Information Constant 12V+ Green/Yellow Switched 12V+ Yellow/Black Ground Black/Light Green Illumination Light Blue/Red Dimmer n/a Antenna Trigger Orange/Blue Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) White/Light Green Right Front (-) Dark Green/Orange Rear Speakers 5" x 7" Rear Deck Left Rear (+) Pink/Light Green Left Rear (-) Dark Blue/Orange Right Rear (+) Pink/Light Blue Right Rear (-) Tan/White Alarm Information Cruise Information |
| Posted on Friday, July 07, 2006 - 06:13 am: |
Thanks ty I will try it I hope it works and I have no clue what a test light is.... |
Post Number: 4 Registered: Jul-06
| Posted on Friday, July 07, 2006 - 06:17 am: |
wait ty you said that blue white is the 12V+ but my car only has Blue Blue Yellow Or white with blue...... So which one is it? |
Post Number: 2580 Registered: Sep-05
| Posted on Friday, July 07, 2006 - 07:14 am: |
use a test light to find out. |
Post Number: 5 Registered: Jul-06
| Posted on Friday, July 07, 2006 - 04:54 pm: |
Ty what is a test light and where could I get one? Cause I hooked up every thing and only had 2 wires left and non of them turned the power on... |
Post Number: 2581 Registered: Sep-05
| Posted on Friday, July 07, 2006 - 05:20 pm: |
just a tool that has a wire on 1 end(ground) and a light tester on other.it allows you to test for current, or if you have a multimeter it will work also. you can get cheap one at advance or autozone.... |
| Posted on Friday, July 07, 2006 - 06:23 pm: |
are you sure its called a test light cause I went to auto zone and they had no clue what I was talking about..... |
New member Username: Qwerner
Inwood,
IA
United States
| Posted on Friday, July 07, 2006 - 07:16 pm: |
any one help with wiring diagram for 2000 dodge durango |
Post Number: 2584 Registered: Sep-05
| Posted on Friday, July 07, 2006 - 09:29 pm: |
then they are stupid, it can be called a circuit tester, bust most people call it a test light.... |
Post Number: 2585 Registered: Sep-05
| Posted on Friday, July 07, 2006 - 09:30 pm: |
2000 Dodge Durango Stereo Information Constant 12V+ Red/Blue Switched 12V+ Red/White Ground n/a Illumination Black/Yellow Dimmer Orange Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) Dark Green Left Front (-) Brown/Red Right Front (+) Brown/Yellow Right Front (-) Brown/Light Blue Rear Speakers 6 1/2" Rear Door Left Rear (+) White Left Rear (-) Dark Blue/Red Right Rear (+) Brown/White Right Rear (-) Brown/Orange Alarm Information Cruise Information |
New member Username: Junkyardogs
| Posted on Saturday, July 08, 2006 - 01:04 am: |
Hey Ty I have a 94 Acura Integra, can you help me out with the wiring colors. Thx |
New member Username: Dixienormas
| Posted on Saturday, July 08, 2006 - 04:06 am: |
Hey Ty, i used the 82' - 85' wiring info, you supplied earlier to someone, to install a new head unit in my 89' celica. so far all worked out well except i was left over with a pink/blue wire that was coming from the car, what is that for? would i be able to get the 89' celica wiring info? Cheers mate, luke. |
New member Username: Rugman29
Moncton,
N.B.
| Posted on Saturday, July 08, 2006 - 11:19 am: |
Hi all. I am lookig for a wiring diagram for a 2000 Intrepid without the Infinity system. Thanks |
New member Username: Theshanefactor
| Posted on Saturday, July 08, 2006 - 01:52 pm: |
I need the wiring colors for a 1988 Toyota Corolla FX... help! Thanks! |
New member Username: Liquidgrin
| Posted on Sunday, July 09, 2006 - 02:39 pm: |
I need the wiring colors for a 1990 ford e150 van, PLEASE! Thank you. |
New member Username: Kdawg
| Posted on Sunday, July 09, 2006 - 04:40 pm: |
ok i have one lightning audio 900 watt 4 channel amp,one lightning audio 600 watt 2 channel amp,one pair of 6.5" 420 watt coaxial speakers,one 12x12"kicker L7 1000watt,one boss audio crossover,and one 1.0farad capacitor. my problem is my 900watt 4 channel amp keeps kicking off when i turn it up loud. please help |
New member Username: Skeeter_alamo
| Posted on Monday, July 10, 2006 - 08:10 pm: |
does anyone have a 2002 Ford econoline E250 radio wiring diagram? |
| Posted on Monday, July 10, 2006 - 09:25 pm: |
disregard ford e250. i traced it out. |
New member Username: Ccicecold83
Mt.laurel,
New jersey
| Posted on Monday, July 10, 2006 - 10:27 pm: |
i need the wiring schematics for a 1990 740 volvo Turbo n will the wires hook right up to the head unit because the stock unit came with a plug for the back so the wires were wrapped as one i have a year old pioneer head unit would it be easier for me to hook it up cause thats how i wanna do it because i didnt think it be that hard or would it be easier to get professionally done because of the way everything is set up like the plug in for the speakers thanks alot for the help |
Post Number: 2593 Registered: Sep-05
| Posted on Tuesday, July 11, 2006 - 06:37 am: |
1985-93 Volvo 740 Series Stereo Information Constant 12V+ Green/Red Switched 12V+ Orange Ground Black Illumination Gray Dimmer n/a Antenna Trigger Red Antenna Left Rear Front Speakers 4" Doors Left Front (+) White/Yellow Left Front (-) White Right Front (+) Gray/Yellow Right Front (-) Gray Rear Speakers 5 1/4" Rear Deck Left Rear (+) Yellow/Brown Left Rear (-) Brown Right Rear (+) Yellow/Black Right Rear (-) Black Alarm Information Cruise Information |
Mt.laurel,
New jersey
| Posted on Tuesday, July 11, 2006 - 09:57 am: |
thanks alot man ill let u no if i have any problems |
New member Username: Damien10101
| Posted on Tuesday, July 11, 2006 - 10:56 am: |
Can any1 help me out with stero wire info for 1995 Ford Probe GT. That be great thx |
New member Username: Ruppe89
GA,
GA
| Posted on Tuesday, July 11, 2006 - 07:39 pm: |
I need a wiring Diagram for a 1993 Honda Ciciv please. E-mail me or send it on here Ruppe89@yahoo.com please. |
GA,
GA
I need a wiring Diagram for a 1993 Honda Civic please. E-mail me or send it on here Ruppe89@yahoo.com please. |
New member Username: Intrepid123
| Posted on Wednesday, July 12, 2006 - 08:16 pm: |
I need a wiring diagram for a 2001 pontiac grand am gt. if you can help me i would really aprecciate it. |
New member Username: Jjspano
| Posted on Thursday, July 13, 2006 - 03:04 pm: |
Need wiring for a 1997 pontiac Grand prix stereo |
New member Username: Smok3n
| Posted on Saturday, July 15, 2006 - 07:01 pm: |
Hi all, Im trying to install A CD Changer for my 1999 honda accord. I have stock CD player. I need the color diagram for the Constant 12v and Ignition 12v. Thx Guys |
New member Username: Corollaman1234
| Posted on Saturday, July 15, 2006 - 10:09 pm: |
Yo whats up guys, i am going crazy trying to find the stereo wiring diagram for a 1999 toyota corolla. If anyone could help it would be most appreciated. Thanks. |
New member Username: Jtmoney313
| Posted on Sunday, July 16, 2006 - 03:50 am: |
i have 2003 olds alero with the stock stereo. can i hookup a 2000watt nitro amp to my stock stereo? if yes please help me out by e-mail at jtmoney313@charter.net thanks!! |
| Posted on Sunday, July 16, 2006 - 03:52 am: |
i have 2003 olds alero with the stock stereo. can i hookup a 2000watt nitro amp to my stock stereo? if yes please help me out by e-mail me at jtmoney313@charter.net thanks!! |
New member Username: Brendon
Windsor,
ON
| Posted on Sunday, July 16, 2006 - 01:57 pm: |
I have a 1997 Ford Mustang with the 460 Mach audio system. I am putting in a Sony Explode cd played. I have purchased the FDK10 wiring harnes for the install and have managed to get the stero to power up and the radio to work but for some reason the cd player comes on and playes cd's but there is no sound from the cd. Any ideas what is wrong? Any help would be appreciated. Brendon |
New member Username: Robbi
| Posted on Monday, July 17, 2006 - 11:11 pm: |
wiring diagram for 93 explorer w/ jbl system.. Thanks |
| Posted on Tuesday, July 18, 2006 - 11:52 pm: |
How do you remove the paneling around a stock radio of a 2003 Olds Alero??? Any info would be helpful and please email at my email address jtmoney313@charter.net |
New member Username: Fastuff
| Posted on Wednesday, July 19, 2006 - 03:20 pm: |
Would a stock 6 CD radio from a 2002 Ranger work in my 1999 F-150 without wiring or mounting changes? |
New member Username: Wholley
| Posted on Wednesday, July 19, 2006 - 04:13 pm: |
hey all..looking for color coded wiring diagram for a 1995 Jeep Grand Cherokee, to install an Alpine I've had for years thats "been around the block"...and by that i mean the harnesses have been removed at one point or another! thanks alot. |
New member Username: Daneliamarco
San Antonio,
TX
| Posted on Wednesday, July 19, 2006 - 06:00 pm: |
Anyone help with wiring diagram for 02 Isuzu Tropper w/rear glass am/fm antena?. Thanks a lot |
New member Username: Bri_bri_marie
| Posted on Thursday, July 20, 2006 - 06:19 am: |
my boyfriend is trying to install a pioneer stero in my truck. Its 89 ford ranger but he has no idea what the wires are. Can someone tell me what they all mean so he doesnt break nething. email me at bri_bri_marie@yahoo.com thanks. |
Post Number: 2633 Registered: Sep-05
| Posted on Thursday, July 20, 2006 - 12:04 pm: |
brandon A, does the radio play and not just the cd p[art, idf so the wires are criossed on the harness(amp turn on and power antenna) |
Post Number: 2634 Registered: Sep-05
| Posted on Thursday, July 20, 2006 - 12:05 pm: |
1993 Honda Civic Stereo Information Constant 12V+ White/Blue Switched 12V+ Yellow/Red Ground Black Illumination Red/Black Dimmer n/a Antenna Driver's Pillar Front Speakers 6 1/2" Doors Left Front (+) Blue/Green Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black Rear Speakers 5 1/4" Rear Deck Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White Alarm Information Cruise Information |
Post Number: 2635 Registered: Sep-05
1999 Honda Accord Stereo Information Constant 12V+ White/Purple Switched 12V+ White/Black Illumination n/a Dimmer n/a Antenna Glass Front Speakers 6 1/2" Doors Left Front (+) n/a Left Front (-) n/a Right Front (+) n/a Right Front (-) n/a Rear Speakers 6" x 9" Rear Deck Left Rear (+) n/a Left Rear (-) n/a Right Rear (+) n/a Right Rear (-) n/a Alarm Information Cruise Information |
Post Number: 2636 Registered: Sep-05
| Posted on Thursday, July 20, 2006 - 12:07 pm: |
PONTIAC / GRAND AM / 2001 / Audio [PRINT THIS PAGE] Radio 12v orange + at radio Radio Ground Radio Ignition yellow + at radio Radio Illumination Factory Amp Turn-on Power Antenna dk. green at radio LF Speaker +/- tan - gray at radio or LF speaker RF Speaker +/- lt. grn - dk. grn at radio or RF speaker LR Speaker +/- brown - yellow at radio or LR speaker RR Speaker +/- dk. blu - lt. blu at radio or RR speaker Back to Top |
Post Number: 2637 Registered: Sep-05
| Posted on Thursday, July 20, 2006 - 12:08 pm: |
1997 Pontiac Grand Prix Stereo Information Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Brown Dimmer Gray Antenna Trigger Pink Front Speakers 5 1/4" Doors Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 6" x 9" Rear Deck Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue Alarm Information Cruise Information 1997 Pontiac Grand Prix Stereo Information Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Brown Dimmer Gray Antenna Trigger Pink Front Speakers 5 1/4" Doors Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 6" x 9" Rear Deck Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue Alarm Information Cruise Information |
Post Number: 2638 Registered: Sep-05
1999 Toyota Corolla Stereo Information Constant 12V+ Blue/Yellow Switched 12V+ Gray Ground Brown Illumination Green Dimmer n/a Antenna Driver's Pillar Front Speakers 5 1/4" Doors Left Front (+) Pink Left Front (-) Purple Right Front (+) Light Green Right Front (-) Blue Rear Speakers 6 1/2" Rear Deck Left Rear (+) Black Left Rear (-) Yellow Right Rear (+) Red Right Rear (-) White Alarm Information Cruise Information |
