Home > Message Board > Car Audio > Security Systems > Archive through August 18, 2006 > Clifford Concept 50 install manual an...
Author Thread: Clifford Concept 50 install manual and options
Username: Wendy_w
Leeds
UK
I want to use my Clifford Concept 50 system after deinstalling it. I need an install manual and want to see what other accessories can be added. Have a glass sensor and Prox sensor already. I know the 50 is lame now but it cost big dosh when I had in installed.
If anyone has a PDF for the 50 install - wendywest@btconnect.com
Username: Ford2581
Post Number: 10
I found this one,
http://www.clifford.com/guides/wiring/concept50_wiring.pdf
Username: Wendy_w
Leeds
UK
Thanks for the info - the Concept 50 is a UK model 70-917 with 24 pins - has a 'hump' intead of the flat design in the guide that is downloadable. Any know of the pinouts for this version?
Username: Wendy_w
Leeds
UK
I have found what I needed - the model is a Concept 50X - wiring diagram is www.clifford.com/guides/wiring/concept50x_wiring.pdf
Thanks for the help folks!
Home > Message Board > Car Audio > Security Systems > Archive through August 18, 2006 > Clifford Concept 50 install manual an... [ « Previous ] [ Next » ]
