Home > Message Board > Car Audio > Speakers > Archive through August 13, 2006 > Multiple component sets?
Author Thread: Multiple component sets?
Username: Justblaze
St.Louis, MO
Post Number: 58
ok, i have a 2004 ford escape and have alpine type-R components in the front with stock speakers in the back. eventually, i plan on replacing the back speakers also. would it sound bad to put another component set in the back? ive heard it messes up the phasing or something if you have moe then one pair of tweeters in a car, is this true?
Username: Rovin
Trinidad & T...
Post Number: 8803
its called imaging
http://www.wickedcases.com/caraudio/rearfill.html .....
Username: Justblaze
St.Louis, MO
Post Number: 59
ok that explains a lot, but i want people to be able to hear more then bass in my back seat. any suggestions? (an escape is a small SUV so the subs are litterally right behind you)
Username: Illuminator
Post Number: 3960
Then throw out imaging and put in some rear speakers.
Username: Justblaze
St.Louis, MO
Post Number: 60
ok, thanks for the info guys
Home > Message Board > Car Audio > Speakers > Archive through August 13, 2006 > Multiple component sets? [ « Previous ] [ Next » ]
