Thread: Ohms question |
Bronze Member Username: Homercleeze
Post Number: 43 Registered: Mar-06
| Posted on Thursday, August 10, 2006 - 06:23 am: |
if i have two 4 ohm 6x9's, what are the options to wire them?? sorry this is a complete n00b question, but i just want to be sure b4 i go buy a 2 channel amp for em. thanks for any input |
Gold Member Username: Tjmutlow
Post Number: 2685 Registered: Sep-05
| Posted on Thursday, August 10, 2006 - 07:53 am: |
on a 2 channel, omne speaker per channel.....can not bridge it.... |
Post Number: 45 Registered: Mar-06
| Posted on Thursday, August 10, 2006 - 03:10 pm: |
so what ohm load would that give me? thanks for the help ty |
Silver Member Username: Troy81
Tavernier,
Fl
Us
Post Number: 912 Registered: Mar-06
| Posted on Thursday, August 10, 2006 - 05:49 pm: |
if you put one speaker to each channel, each channel will have 4 ohms, which is what most amps are rated for |
Gold Member Username: Illuminator
Post Number: 3963 Registered: Apr-05
| Posted on Saturday, August 12, 2006 - 12:27 am: |
What is essentially being said is this: there are no options to wire them. You hook the positive to positive and negative to negative and you're done. You can wire them in series or parallel, but then you will have to power them from one channel, and lose stereo seperation. If you wired them as such, you would gain next to nothing unless you were trying to do some crazy install which certainly doesn't seem to be the case. |
