Thread: What is clipping? |
Silver Member Username: Crayola0
Wisconsin
Post Number: 451 Registered: Jun-06
| Posted on Sunday, August 06, 2006 - 12:02 pm: |
Bronze Member Username: Riskyb
Post Number: 39 Registered: Feb-06
| Posted on Sunday, August 06, 2006 - 12:08 pm: |
Its basically over working an amplifier. The waves an amp puts out are supposed to be sine waves but when an amp clips it cannot fully amplify the trough and crests of the wave (top and bottom) causing a square wave. This is bad for the amplifier and you will notice alot of distortion in the sound. |
Gold Member Username: Basshead86
Google is your Friend,
FL
Post Number: 4264 Registered: Aug-05
| Posted on Sunday, August 06, 2006 - 12:13 pm: |
it clips the top and bottom off of the sine wave making it a square wave. and thus sends DC(direct current) to your subwoofer's VC. |
Wisconsin
Post Number: 452 Registered: Jun-06
| Posted on Sunday, August 06, 2006 - 01:04 pm: |
so from like having ur gain all the way up. |
Post Number: 41 Registered: Feb-06
| Posted on Sunday, August 06, 2006 - 01:07 pm: |
It all depends but, yes on most amps having the gain all the way up will cause clipping. |
FL
Post Number: 4265 Registered: Aug-05
| Posted on Sunday, August 06, 2006 - 01:24 pm: |
^^^^^b/c almost no HU put out only .2-.5V at 3/4 volume. so yeah. lol |
