Home > Message Board > Car Audio > Amplifiers > Archive through August 06, 2006 > Big help!
Author Thread: Big help!
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 1691
i need a 1000w rms amp at 4 ohms, subs are 8 ohm SVC (weird for car audio) and i'm on a budget, i was thinking about buying an audiobahn a8002t, but i really need 1000w rms or more at 4 ohms, any help will be appreciated...
Username: Ctmike
Ct.
Post Number: 1241
what kind of budget?
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 1696
Username: Ctmike
Ct.
Post Number: 1244
how much you looking to spend for the amp? you try ebay, i found a few xenons and alpine's, the new models, but there anywhere $350-$550 so i don't know.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 1697
maybe i can strap two abahns a8000V or T, is cheaper than all the options...
Username: Tjmutlow
Post Number: 2669
use a 2 channel bridged, not a mono, unless it is like the JL or Xeon seires PG. what subs are you running, you should be matching amp to rms rating not max power, so i am assuming the rms for those subs are 500w if your asking for a 1000w amp...
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 1699
that's what i think, i'm not going to give them 1250w to each cuz i know they will blow/sound bad so i was thinking about 500w rms each, yeah i need a 2 channel bridged, or two strappable amps running at 4 ohms, i think i'm going to buy another vibe 1800d (2400w rms+ at 2 ohms, at 4 ohms at least should be 1000-1300w rms don't you think??????)
Home > Message Board > Car Audio > Amplifiers > Archive through August 06, 2006 > Big help! [ « Previous ] [ Next » ]
