Thread: NINe 1 question. |
Bronze Member Username: Kenkenni
Post Number: 16 Registered: Jun-06
| Posted on Saturday, August 05, 2006 - 09:55 pm: |
How will this amp handle 2 Power Acoustic 10" MOFOs in a a dual 10" ported box. |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 1686 Registered: Dec-05
| Posted on Saturday, August 05, 2006 - 11:13 pm: |
the amp will blow those subs, can you sell them?? nice amp BTW, bad subs... |
Post Number: 17 Registered: Jun-06
| Posted on Sunday, August 06, 2006 - 12:14 am: |
juliob, the subs are on my wish list to buy. Still trying to get a good system together. These subs have an RMS of 1000 and a peak handling of 2400. The NINe 1 is rated at 1200 x 1 at 1 ohm mono.I plan on running the subs wired down to 1 ohm stable. These aren't cheap quality subs either if you check their website. Why do think this amp will blow these subs? I'm still trying to grasp this car audio stuff so enlighten me. Ken. |
Gold Member Username: Ctmike
Ct.
Post Number: 1238 Registered: Feb-06
| Posted on Sunday, August 06, 2006 - 12:17 am: |
power acoustic sucks, they should never make anybodys wish list. what's your budget for subs, anyone in the world can help you pick better subs than those. |
Gold Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 8395 Registered: Jul-05
"These aren't cheap quality subs either if you check their website." Yes they are....of course their website will try and sell u that sub...why wouldnt they try and sell there product??? That Nine.1 will put more power to those subs then they can handle.... what is ur budget for subs??? |
Post Number: 18 Registered: Jun-06
| Posted on Sunday, August 06, 2006 - 12:30 am: |
My subs budget is about $400 or $200 per sub. But I want powerful subs. I still can't see how this amp will overpower these subs. |
Huntsville,
Alabama
U.S.
Post Number: 8397 Registered: Jul-05
| Posted on Sunday, August 06, 2006 - 12:33 am: |
because those subs will not handle the 1000rms they claim....they are made cheap....have no sound quailty and blow very very very easy... do u want stupid loud....great sound...or a mix of both??? |
Post Number: 19 Registered: Jun-06
| Posted on Sunday, August 06, 2006 - 12:51 am: |
I'll take a little of both. I plan on making a purchase on subs this coming Thursday as I managed to have a little bit extra left on the paycheck so any powerful sub suggestions you can give me is appreciated. |
Ct.
Post Number: 1239 Registered: Feb-06
| Posted on Sunday, August 06, 2006 - 12:55 am: |
2 arsenals are in your budget. a little more you can get 2 rl-p's. maybe one dd 3512 on that amp if you want one sub, or 2 dd 2512's. |
Huntsville,
Alabama
U.S.
Post Number: 8402 Registered: Jul-05
do u already have that amp??? if not u may need an electrical system upgrade to run everything properly... |
Post Number: 1692 Registered: Dec-05
| Posted on Sunday, August 06, 2006 - 12:59 am: |
yeah |
Post Number: 20 Registered: Jun-06
| Posted on Sunday, August 06, 2006 - 01:05 am: |
The amp will be bought right along with the subs. Are those model numbers you giving me all apart of the Arsenal subs. |
Ct.
Post Number: 1242 Registered: Feb-06
| Posted on Sunday, August 06, 2006 - 01:09 am: |
dd=digital designs http://www.ddaudio.com/dd/default.asp soundsplinter rl-p http://www.soundsplinter.com/ ascendant audio arsenals http://ascendantaudio.com/index.html and chauncy's right, you might need to upgrade your electrical system first. |
