Home > Message Board > Car Audio > Amplifiers > Archive through August 06, 2006 > Amps for atomic
Author Thread: Amps for atomic
Username: Big_fletch
Newport, Ar, Ar
United states
Post Number: 358
im gettin a atomic apxx 18 subwoofer and im needin alot of power to make this thoing hit 160 to low 170 db's i have a escalade so im buildin a huge box for it u think i should port it? anyways im wonderin what amps i should get for it that wouldnt cost over 1000$ i wanna be able to reach 170's in db or is that possible with this sub? what amps should i run
Username: Dustin3
Tigard, OR
U.S.
Post Number: 2891
what!!! what about ur l7 and memphis 1100?? whats the rms on that sub
Username: Dustin3
Tigard, OR
U.S.
Post Number: 2893
LOL, and you dont need that sub unless ur competeing. because you can give it 5000 daily
Newport, Ar, Ar
United states
Post Number: 362
i need it lol im gonna start competin alot and im wantin to hit big numbers on the db how many hifonics bxi amps can i strap on that amp ?
Username: Dustin3
Tigard, OR
U.S.
Post Number: 2900
prolly 10 +
or 5-8 orion 2500d's
not inclusing ALL OF:
Wiring for each amp
HUGE ALTERNATORS -- 2-3 alts (250a each)around
batteries
Newport, Ar, Ar
United states
Post Number: 363
screw that lol im not that rich right now i just want my system to be louder i want somethin that will hit in the 170's lol what do u suggest bassman
Username: Dustin3
Tigard, OR
U.S.
Post Number: 2901
170 is a number that is toooooo high of a mark. no1 on this forum can hit 170's, even with all of the great box builders and the people who buy good quality equipment.
get a couple memphis Mojo's 15" with a good amp, and it will be pretty loud. look at some DD, Treo, MMats, etc.
a more reasonable goal would be 150
Newport, Ar, Ar
United states
Post Number: 365
hey what u think im httin right now with my 15 L7 powered by the memphis? around what im hittin.........if i added annother L7 u think i could just get a good amp to power both of them and it would be puttin some big numbers?
Newport, Ar, Ar
United states
Post Number: 366
bump
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 1687
Tyler if i were you i wouldn't get that sub, cuz you're going to need too many things just to hear it hehehe...
if you want, you can do chauncey's old setup... four 15s with 4 1200w rms+ amps, hitting the sh1t out of those subs and you'll be happy if you don't care about SQ hehehe
Username: Dustin3
Tigard, OR
U.S.
Post Number: 2904
lol. i think he hit 169 with that set-up
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 1694
yeah, that's a good/kinda cheap SPL system, you get 3 more 15 l7, get 2 PA a3000db, 2 subs per amp wired at 1 ohm... good electrical upgrade, and earplugs
Newport, Ar, Ar
United states
Post Number: 373
damn that would set it off lol
yea but im thinkin about just addin another 15 L7 and powerin by the rockford fosgate t2000
what you think ill be hittin if i get a good box ported and use 1 gauge wire all the way
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 1698
t2000 is vey powerful, like 2700w rms, IDT they can handle that amount of power... you should hit 150Dbs or more
Newport, Ar, Ar
United states
Post Number: 374
but i can turn the amp down if i have to right or can i?
Newport, Ar, Ar
United states
Post Number: 375
and when i get a new alternator will that make my 15's be louder? and do i need another batttery
Username: Ctmike
Ct.
Post Number: 1245
yeah upgrade the battery and big 3 when you get a new alt. and what you mean turn the amp down if you have to?
Newport, Ar, Ar
United states
Post Number: 377
since it puts out around 2500 to 2700 rms watts you think i should adjust the amp level and all that so it wont blow the subs
so u think i should go with 300 amp alt
Username: Ctmike
Ct.
Post Number: 1246
if you think you can control the power the amp puts out by the gain on the amp your wrong. if thats what you mean. and yeah a 300a alt. would be good.
Newport, Ar, Ar
United states
Post Number: 379
yea i was forsure most plp says i can put i didnt see how and some plp say i cant so im goin with your advice but i think thats a good amp what u think?
what kind of battery do i need?
Newport, Ar, Ar
United states
Post Number: 380
yea i wasnt forsure most plp says i can put i didnt see how and some plp say i cant so im goin with your advice but i think thats a good amp what u think?
Username: Ctmike
Ct.
Post Number: 1247
never used the amp so can't comment on that. i'd get a alt. from iraggi or excessive, yellow top battery, and do the big 3 and you should be good to go.
Newport, Ar, Ar
United states
Post Number: 381
alright man thanks for the info i will tell u when i get the setup done
would it work with just a 250 amp alt or even a 200 amp?
Username: Ctmike
Ct.
Post Number: 1249
if i figured it right, i think for 2000wrms you'll need 200a for the system, that's without the power you'll need for your car. i'd go 250a smallest, but if you have it get the biggest alt. you can. i could be wrong on that though.
link on charging systems:
http://wickedcases.com/caraudio/charging.html
Newport, Ar, Ar
United states
Post Number: 383
kk thanks
Home > Message Board > Car Audio > Amplifiers > Archive through August 06, 2006 > Amps for atomic [ « Previous ] [ Next » ]
