Thread: I need HELP with some things... |
New member Username: Isuzdude05
Post Number: 6 Registered: Jun-05
| Posted on Saturday, August 05, 2006 - 12:46 am: |
I have a 2000 Isuzu Rodeo with 2 12" Power Acoustik FUBR Subs (200 oz Magnet, 700rms 1800peak) 1800 Watt monoblock kenwood amp, I have them in a sealed box wich is not big enough for how much air they push, it feels like they are going to explode when they hit with low bass notes. So I am trying to decide what kind of box to upgrade to, ported or sealed (bigger) kind of want to get a ported box,I also need a capitor iw as thinking 3 Farad but not sure, PLEASE any help would be greatly appreciated, thank you! |
Gold Member Username: Ctmike
Ct.
Post Number: 1224 Registered: Feb-06
| Posted on Saturday, August 05, 2006 - 12:50 am: |
if you want more sq, stay sealed. more spl then ported. and you don't need a cap. unless you already have a ho alt. and even then a cap. isn't really needed. and what's the specs of that amp, rms not peak? |
Post Number: 8 Registered: Jun-05
| Posted on Saturday, August 05, 2006 - 01:01 am: |
sq=? (im an idiot) 900rms 1800 max and my lights dim like nothing when they hit |
Silver Member Username: Bigsim
Australia
Post Number: 153 Registered: Jan-06
| Posted on Saturday, August 05, 2006 - 03:16 am: |
sq= sound quality, spl = sound pressure level (loudness). I don't know much about capacitors, but GW's site at http://wickedcases.com/caraudio/capacitors.html is handy. Read this paragraph in particular: "So by adding a capacitor to try taking the place of a high-output alternator, you are actually causing more work for your alternator, and causing even more damage to that stock alternator." |
Post Number: 9 Registered: Jun-05
| Posted on Saturday, August 05, 2006 - 03:12 pm: |
Which do you guys look more for sq or spl? |
Silver Member Username: Crayola0
Wisconsin
Post Number: 425 Registered: Jun-06
| Posted on Saturday, August 05, 2006 - 03:39 pm: |
i like spl. i just want to be heard |
